AUX on radio - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 12-03-2014, 02:46 AM Thread Starter
AUX on radio
I recently picked up a '95 Caprice Wagon. On the CD button on the radio it's also marked AUX. Is there an input somewhere? I noticed back by the rear speakers is what looks to be an 1/8" audio jack. Is that it? Kind of a weird setup if it is.
1995 Caprice Wagon
1996 Caprice 9C1
Winger67 is offline
post #2 of 11 (permalink) Old 12-03-2014, 06:26 AM
Not sure as I run an Aftermarket Head unit, but there is lots of info if you just "SEARCH" for it. Here is just 1 thread that search found when using "AUX JACK"....
https://www.impalassforum.com/vBulletin/showthread.php?t=269845&highlight=AUX+jack
post #3 of 11 (permalink) Old 12-03-2014, 07:17 AM Thread Starter
I did search and didn't find anything related to AUX on a stock head unit. I guess it's a head unit from a different car. I'm still wondering what the jack near the rear speaker is.
1995 Caprice Wagon
1996 Caprice 9C1
Winger67 is offline
post #4 of 11 (permalink) Old 12-03-2014, 09:39 AM
If that jack by the rear speakers appears to be factory, then it "could" be for the CD Changer. I believe some cars from the factory had CD Changers mounted on the Under Side of the Package tray where the rear speakers are.
Maybe look up info on the CD Changer and see what you find. If you can post up a pic of the connector, then others may recognize what it is.
post #5 of 11 (permalink) Old 12-04-2014, 09:57 AM
93capriceltz's Avatar
The AUX button on the OEM unit controls either a trunk mounted CD Changer, or a Slave Cassette or CD Player (as seen in the trucks and vans). It requires you to install the OEM connector cord between the two devices
1993 Caprice LTZ / LS:
51,000 miles, L05, 3:08 Posi, Harris Prom, Lowering Springs, Bilsteins,
96 Steering Wheel, 9C1 Hoses, Dual Snorkel Intake,
SS Rear Disks, J55 Fronts, High Flow Cats, Dual Exhuast, Fleetwood Horns and Center Console, Roadmaster Rear Door Lights, LED Interior
1992 Caprice Wagon: Black Sapphire/Silver, L05, Tow Pack, 3:23 Posi, 9C1 Cluster, 96 Steering Wheel, Fleetwood Horns, LED Interior
1996 9C1 - Former Whelen Trade Show Car - SOLD
1994 SS - SOLD
1991 9C1 - SOLD
93capriceltz is offline
post #6 of 11 (permalink) Old 12-04-2014, 11:09 AM
95wagon's Avatar
One thing to note,
in a 95-96 Chev CD player with aux, it can only run a remote TAPE player .
It is not "smart " enough to run a remote CD or Ipod through the aux plug on the back of the radio .
To run a CD stacker or Ipod , the Cassette player with AUX was needed.
The work around if someone wants both a CD radio and a stacker or Ipod is the last year of the same gen radio from an S10 (2002?)
It has a CD/AUX button there.
one tap- internal CD , double tap- AUX
I use it with an Ipod adapter
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
post #7 of 11 (permalink) Old 12-05-2014, 12:25 AM Thread Starter
Ha! What I thought were 1/4" audio inputs near the rear speakers I now believe are mounting points for the cargo screen. They're in the panel indentations on both sides.
So it sounds like the AUX isn't very useful without an expensive adapter if at all. This is similar to the C5 Corvette radios but someone found a way to add an standard AUX input by splicing/soldering. Haven't done it to my C5 yet but if it goes well, I might try hacking the Caprice radio as well. Thanks for all the help.
1995 Caprice Wagon
1996 Caprice 9C1
Winger67 is offline
post #8 of 11 (permalink) Old 01-09-2015, 09:32 PM
_E_
I added my own "AUX" by dissecting my deck, tapping into the FM audio L/R channels and adding a relay to toggle between FM and AUX. Then I added a bluetooth receiver to the AUX line, so I can now play music over bluetooth via my stock deck. I posted a thread about it as I went along. It's a few years old and a little difficult to follow, but it's a fun project and the results are good, for those interested.
_E_ is offline
post #9 of 11 (permalink) Old 01-09-2015, 10:04 PM
_E_
I sniffed around and found the original post on how to install an AUX line, as per dservati.
https://www.impalassforum.com/vBullet...=240045&page=2
What I did was install a wire with a 3.5mm male connector instead of a female connector, then I ran the wire to a bluetooth receiver. It didn't work initially, but I found the proper filter to add to the audio line between the bluetooth receiver and the deck, and it's been smooth sailing ever since. Everything is concealed, so nobody would ever know the car has an AUX line. I like that.
_E_ is offline
post #10 of 11 (permalink) Old 01-10-2015, 01:11 PM Thread Starter
Awesome! That's exactly what I was looking for. Thanks!
1995 Caprice Wagon
1996 Caprice 9C1
Winger67 is offline
