Satelite Antenna - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 12-04-2014, 05:46 PM Thread Starter
Satelite Antenna
Were is a good place to put a satelite antenna on my 96 RMW? XM said to put it on rear roof but that doesnt leave the room that it needs 3in.steel all way around
Tombstonebilly is offline
post #2 of 6 (permalink) Old 12-04-2014, 07:50 PM
ocala's Avatar
I brought it up under the dash. The small magnetic antenna. I put it inside the defrost vent. Never had a problem with reception.
I had the dash out at the time, so I'm not sure how difficult it would be to locate there otherwise.
ocala is offline
post #3 of 6 (permalink) Old 12-04-2014, 08:35 PM
What does it look like?
post #4 of 6 (permalink) Old 12-04-2014, 09:24 PM
jose7740's Avatar
I had mine above the windshield, cable under the weatherstripping.
jose7740 is offline
post #5 of 6 (permalink) Old 12-04-2014, 10:13 PM
Northern Classics's Avatar
On 96 RWM, I have magnetic antenna within the roof rack area, about four inches to the rear of the skylight. Perfect reception. Use the same place (within the roof rack) on the 89 Caprice, 86 Caprice and 93 Dodge Caravan. As already posted, hide and protect the tiny antenna cable inside the weatherstrips.
And here there is no terrestrial network, so only XM reception is from satellite.
Generally 70 - 80% signal strength (sat) and 0% signal strength (terr).
If you live in a more urbanized area than the arctic circle (like me), you may be able to get away with the antenna being inside the car where it can still receive the terrestrial network signal.
''know this: Unless you slam into the rocks, chances are good that you won't die immediately when you hit the water. It will hurt like all hell. Your broken body will struggle to stay afloat. Intense pain for who knows how long before you finally succumb to a horrid drowning death. Maybe you will survive after all, now with life long debilitating injuries. Are you really up for that?''
- Philip Aisheo
Northern Classics is offline
post #6 of 6 (permalink) Old 12-05-2014, 06:25 PM Thread Starter
Fred, I think it looks like a half bar of ivory soap as I havent seen one up close.
