amp wire through firewall - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 02-13-2015, 03:06 PM Thread Starter
i peeped out under my dash to see if there would be a easy spot to run my 1/0 gauge wire through but dont see anything. i dont mind drilling but right now my charger is lost. the car is a 93 caprice with the 305 not sure if the firewall changed much.
i would like to know where and how did you guys run your wires?
jaymoung is offline
post #2 of 8 (permalink) Old 02-13-2015, 09:42 PM
Joe B.'s Avatar
This location on the passenger side worked for me.
Easy access on both sides of the firewall.
'91 Caprice wagon. My driver since '99, now semi-retired.
It's officially an antique.
Joe B. is offline
post #3 of 8 (permalink) Old 02-14-2015, 03:00 AM
Try Harbor Freight. There is a tool for this that makes it easy to go thru any of the holes with rubber inserts without damaging the rubber.
Jim B.
fbi9c1 is offline
post #4 of 8 (permalink) Old 02-15-2015, 08:27 AM Thread Starter
whats it called?
jaymoung is offline
post #5 of 8 (permalink) Old 02-15-2015, 08:27 AM Thread Starter
i must have to remove some panals because i didnt see that when i pull up the carpet
jaymoung is offline
post #6 of 8 (permalink) Old 02-15-2015, 10:36 AM
SLIM•B's Avatar
I skipped drilling through the firewall and ran it underneath the car and through the frame then made a hole to come through the trunk with it. I also ran 1/0 gauge, haven't had any issues.
96 Caprice 9c1 bagged lambo doors 24s(SOLD)
92 Caprice L03 white on white custom system 24s(SOLD)
96 Caprice L99 24s (SOLD)
96 Caprice L99 DGGM Impala clone dropped custom system 24s (SOLD)
94 Caprice B4U custom system lifted 26s(SOLD)
96 Impala SS DGGM on coil overs
SLIM•B is offline
post #7 of 8 (permalink) Old 02-15-2015, 07:03 PM
Joe B.'s Avatar
Yes, the lower dash panel on pass side.
This is a good location for a wire to the head unit/dash.
If you're going to the rear of the car, I'm sure there are better routes like under the car as Slim suggested.
Joe B. is offline
post #8 of 8 (permalink) Old 02-21-2015, 05:55 PM Thread Starter
this is what i see on my pass side if it wasn't so cold here in michigan i could spend more time looking lol
jaymoung is offline
