Alternator whine from speakers - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 07-21-2015, 09:21 AM Thread Starter
cashmoneyspeed's Avatar
I removed my old Sony tape deck and installed a Jensen vm9312 with flip out touch screen and am getting a real low constant whine mostly audible at idle or with radio on but not playing. With the volume up a bit i cant tell theres any "white noise". I never had this problem before and all equipment in the trunk is the same. Power wires run down one side of car, rcas down the other side. Crossover in trunk with separate amps for subs and interior speakers. I changed nothing except the head unit. I have not hooked up the parking brake wire on the head unit that allows video play. Everything else is wired, solid connections.
Any feedback on the Jensen brand when it comes to whine?
94' 9C1 20" Lexani Krystals or 14" Chrome & Gold Daytons depending on my mood, Intrax springs, belltech shocks, Moog suspension, body bushings, stealth bolt, Smoothie bumpers, 91 tails, chrome pillars, K&N Intake, Fuel Rail Covers, New interior, custom grill, shaved, powdercoated parts, and so on..
cashmoneyspeed is offline
post #2 of 7 (permalink) Old 07-21-2015, 02:52 PM
Can't speak for the Jensen but I have seen similar issues with aftermarket units. Try and run a Stranded Wire from the Radio Chasis to a Metal point (ground) on the car and see if that helps.
post #3 of 7 (permalink) Old 07-22-2015, 01:10 PM
You likely have a ground loop. Check your grounds and RCA connectors. One may be loose.
threeimpalas is offline
post #4 of 7 (permalink) Old 08-07-2015, 08:59 PM Thread Starter
All grounds and connections were good. I ran a wire from the radio to ground and no more interference noise.
post #5 of 7 (permalink) Old 10-22-2015, 09:25 PM Thread Starter
Ahhhhhhh the noise is still there and noticeable at low volume using cd's. its slightly less with the radio stations.
post #6 of 7 (permalink) Old 10-22-2015, 10:35 PM
96SSbbb's Avatar
Back in the day my dodge truck with a Sony unit did the same thing, I checked stuff to no end. Figured it out after a tune up a year later, plugs and wires.
ISSCA# 930
96SSbbb is offline
post #7 of 7 (permalink) Old 11-21-2015, 05:33 PM
1FAST94's Avatar
Yup, it only takes one bad plug wire to cause alot of noise.
Mike Harris
B-BODY PERFORMANCE
Dayton, Ohio
10.43 @126.95 @ 3800 lbs.
http://www.youtube.com/watch?feature...&v=a8dYCl2cAdM
1FAST94 is offline
