6x9s in front door - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 09-12-2015, 04:54 AM Thread Starter
Send a message via AIM to GrapeApe
6x9s in front door
so I was thinking of replacing the old 6.5s..one of them is rattling,
so was thinking about and if 6x9s will fit in the front door?
GRAPEAPE 96 DCM
GrapeApe is offline
post #2 of 9 (permalink) Old 09-12-2015, 12:27 PM
GSBULLDOG's Avatar
There were some on here long ago that claimed that the 6x9 would fit but no real proof of it .
GSBULLDOG is offline
post #3 of 9 (permalink) Old 09-16-2015, 07:43 AM
fuzzcar's Avatar
It would have to be a shallow 6x9. Theres deffinately enough room
fuzzcar is offline
post #4 of 9 (permalink) Old 09-30-2015, 06:30 AM
ejschultz's Avatar
Why would you sacrifice the sound quality of a round speaker for the mediocre sound quality of a 6x9?
-94 Caprice Classic LS - system, Gary's wires, 200 amp alt, tint, first base/home plate delete, clear corners w/green parking lights, LTZ hood emblem, SS springs
-97 Grand Cherokee TSi - 4" IRO lift, OEM skids/hooks/hitch, sliders, 31s, rear locker, system, tint, cloth, clear corners, Magnaflow stuff
Refs: DesertDawg, 214Texas, QUICKSSILVER, SSon22s, MadMav, gary burton
ejschultz is offline
post #5 of 9 (permalink) Old 10-06-2015, 06:39 PM
CapriceCarl's Avatar
I'm still using (what I assume are) the stock speakers, and just upgraded to an aftermarket head unit. The sound is nice and crisp until I raise it up so loud that the base begins to interfere and distorts the rest of the sound out a little bit.
I don't know too much about speakers, but if I replaced them- would I be able to get a little more base with clearer sounds at higher volumes? I don't want to run amps and subs. Just get a little kick with the audio quality not taking a hit.
CapriceCarl is offline
post #6 of 9 (permalink) Old 10-06-2015, 09:55 PM
KW Baraka's Avatar
Originally Posted by CapriceCarl View Post
I'm still using (what I assume are) the stock speakers.........if I replaced them- would I be able to get a little more base with clearer sounds at higher volumes? I don't want to run amps and subs. Just get a little kick with the audio quality not taking a hit.
I installed a set of Kicker KS600 (6" round) speakers in my '96 Impala....they cost about $60-$70 for a pair. Great sound!
When my '95 comes back from the shop, it's gonna get a matching set !
https://www.google.com/?gws_rd=ssl#q=kicker+ks600
https://www.youtube.com/watch?v=u3cxuRTkhh4
KW
KW Baraka is offline
post #7 of 9 (permalink) Old 10-07-2015, 06:23 AM
You could just go with some 4x6 (stock size) plate type aftermarket speakers that will bolt right in. They will sound much better than stock but this size doesn't handle many watts compared to some of the other sizes out there. I had a pair in the car for a while (can't remember the brand) that I got from Crutchfield and later sold to another member and running a head unit with 50w per channel.
Once you upgrade the head unit with more watts and push them, they just don't sound as good compared to the rears. A lot of us have increased the size and power handling with a set of round 6.5" speakers that will fit and by design can handle more wattage and sound a little better. This could be a good option for you with a stock or upgraded head unit.
https://www.impalassforum.com/vBullet....php?t=1264137
post #8 of 9 (permalink) Old 10-07-2015, 11:27 AM
Right on. Thanks guys, I greatly appreciate it. I'll look into upgrading all fours.
The wagon rears are 6x9 correct? Will that KS600 fit in the doors? They sounded pretty awesome in that video, although I'm not sure how long his will last, lol.
I just want to listen to so Old School rock and roll
post #9 of 9 (permalink) Old 10-07-2015, 12:46 PM
KW Baraka's Avatar
.....Will that KS600 fit in the doors?.....
That's where I put mine. Direct replacement for the front stock speakers.
KW
