New system going in - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 12-08-2018, 04:47 PM Thread Starter
4x4high's Avatar
New system going in
It's been many years since I've had a good stereo system and that's all about to change here shortly. I recently installed a new Alpine deck CDE-175BT and just last week I ordered a Rockford Fosgate P1000X5 amp, RFC1D 1 Farad Digital Capacitor, RFCB140 140 amp circuit breaker, T1650 6.5" 2 way coax speakers, T1692 6"x9" 2 way coax speakers, Kicker Free air KFM104 subs, and a complete Fosgate wire install kit.
1996 DGGM Impala SS
4x4high is offline
post #2 of 7 (permalink) Old 12-12-2018, 01:01 AM
SSJason's Avatar
I'd love to see pics! I'm getting ready to put in a new system in my 96DCM as well. Need to deal with a rear oil leak first then decide what head unit to go with (single din or double).
SSJason is offline
post #3 of 7 (permalink) Old 12-29-2018, 06:40 PM Thread Starter
4x4high's Avatar
Finally made a new baffle board and mounted the subs and test fit to make sure everything was going to fit correctly. Now I just need to remove the back seat and drill some mounting holes to hold the baffle board and install the inserts into the baffle board before I can cover it with trunk liner material to finish it off.
1996 DGGM Impala SS
4x4high is offline
post #4 of 7 (permalink) Old 01-01-2019, 05:15 PM Thread Starter
4x4high's Avatar
A little further progress today. I built a metal bracket that will keep the hinge covers in place properly and also be the mounting location for the board that will hide everything from the trunk opening forward except the portion of the spare tire that will protrude through the backside. Next will be to make a template so I can cut said board and install it.
1996 DGGM Impala SS
4x4high is offline
post #5 of 7 (permalink) Old 01-02-2019, 06:18 AM
Frasierraheen's Avatar
Looking great so far, I cant wait to see the final result. Please keep the pics coming
Save the Wago's
Frasierraheen is offline
post #6 of 7 (permalink) Old 02-08-2019, 09:25 PM Thread Starter
4x4high's Avatar
Figured I'd give an update. The project got put on hold for now since the wife blindsided me with "she wants a divorce". That along with the rain and no indoor space to do anything put it on hold for now at least until I get some sunny weather to work with.
1996 DGGM Impala SS
4x4high is offline
post #7 of 7 (permalink) Old 05-18-2019, 12:11 AM Thread Starter
4x4high's Avatar
Well I'm back to working on this stereo upgrade. Started by pulling the driver door panel off so I can mount the speaker adapter.
Not sure why these pics rotated once uploaded, sorry about that I don't know how to fix that.
I started off by using an existing hole in the door skin to install a 1/4-20 Klik Poly-nut insert. Next I had bought a pair of speaker adapters so I now laid it in place and used the new mounting hole and proceeded to marking the other 3 bolt hole locations. Now I removed the adapter and drilled the next 3 holes and installed the Klik Poly-nut inserts in those locations as well. Now I bolted the adapters in place and then mounted the speakers to the adapter with a Boom Mat between the speaker and adapter. Next I reinstalled the door panel only to find out the adapters I bought won't work with the speakers I'm using because it pushed the speakers too far out towards the door panel and they hit the door panel pretty bad. So I removed everything and used the adapters as templates to make some new adapters that were flat rather than the roughly 5/8" extended ones I bought. Now that the new adapters are made I bolted everything back together and this time the speakers clear without any issues. I did need to cut some of the inner door skin to clear the frame of the speakers.
Name:	Driver door inner skin speaker area.jpg
Name:	Driver door rivnut insert.jpg
Name:	Driver door rivnut inserts installed.jpg
Name:	Custom made speaker adapter.jpg
Name:	Driver door speaker and adapter installed.jpg
1996 DGGM Impala SS
4x4high is offline
