Running rockford 1/0 gage wire on passenger side - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 02-04-2012, 06:22 PM Thread Starter
96hvychvySs's Avatar
I don't know if a lot of you already know this, but I just discovered this today with my buddy showing me this little trick..
After you drop the wire pull the carpet back and you'll see the factory wires..
Here is a pic of the passenger side rear..
Now running up to the trunk..
Ran out of matt..trunk is covered all the way up to this point..
96hvychvySs is offline
post #2 of 9 (permalink) Old 02-05-2012, 10:40 AM
94MI9C1's Avatar
Yep seen it before, nice pics. Honestly, and this is just me, that heavy gauge of wire I usually run on the outside of the car, for various reasons. Looks nice though the way you routed it for sure.
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #3 of 9 (permalink) Old 02-05-2012, 11:43 AM Thread Starter
Thanks man..My buddy came over and showed that to me..(I had 4 gage ran on the driver side) just for conversation what are the various reasons?
post #4 of 9 (permalink) Old 02-05-2012, 11:50 AM
Mr pogo's Avatar
I ran mine that way long ago, thru the sweet spot below the heater that people recommended.
just be carefull of sharp edges going thru the rear seat/trunk opening, I think I put mine thru closer to the rear wheel well.
and fuse it up by the battery.
Mr pogo is offline
post #5 of 9 (permalink) Old 02-05-2012, 12:00 PM Thread Starter
Right on thanks for the heads up..I have a extra battery in the trunk..So 3 circuit breakers..one after main battery, before second battery, and after the second battery going to the amp..I have some more things to do to the audio before I can post some more pics..cant wait to finally put my front door panels on so I can install the 6 1/2'' boston pro's and hook up the 4 channel..It's been a long time coming
post #6 of 9 (permalink) Old 02-05-2012, 01:58 PM
rileycoastie's Avatar
looks sweet bro. i did the same thing last year when i upgraded my system!
WHO DAT NATION! ISSCA#2463
95 DCM/BBB SS-22" U2 55, 3D Polished Grill, Custom Audio, Double din DVD "flip out", Hooker Headers, 2.5 Flowmaster 40 Series, Underdrive pulley, F Body MAF, Tuned, Shift kit, 160 thermo, Euro Headlights, DDM Tuning HID's 55W 6000K, Smoked Tails with LED sequentials , Custom black carpet, Corvette starter, Yellow top optima, Big 3 upgrade, Smaller alternator pulley.
rileycoastie is offline
post #7 of 9 (permalink) Old 02-05-2012, 03:24 PM
94MI9C1's Avatar
I just like to have very heavy current capable/carrying wiring outside of the passenger area. The way you have yours is nice, I have seen some really shady installs in the past though. Chafing would be my highest concern, but it looks like you did it right
Mike
ISSCA member # 2344
Hoosier INC Member
94MI9C1 is offline
post #8 of 9 (permalink) Old 02-06-2012, 10:07 AM Thread Starter
Thanks guys, I'll be sure to put loom for the entrance and exit so no Chafing happens..I still have to get my black carpet so the SS is still apart
post #9 of 9 (permalink) Old 02-14-2013, 09:39 AM
DB
Thanks! Did this last night!
Much cleaner and more well hidden than driver side. Plus you save about 6 feet of wasted cable
Dustin Burke
1994 Impala
DB is offline
