Adding MP3 Jack - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 03-02-2012, 10:24 PM Thread Starter
impala79's Avatar
Adding MP3 Jack
At one time I was going to add the remote disk changer to my 95 Caprice wagon. As technology has obsoleted that, it seems to me that it should be easy to use the input for the remote CD (aux) for a line-in from a blackberry headphone jack using the blackberry as an MP3 player.
Has anyone done this? What is needed? I would like to preserve the factory look by using the existing radio.
Greg
\'96 DGGM B4U, 147k - PMCAIS, Impala grille, wheels, and tail lights, SEO p/s cooler, slotted rotors, Hawk pads, Scott Mueller body bushing mounts, Bilstiens
\'95 Caprice Classic Wagon, MGR, 218k - PMCAIS, TB Bypass, SEO ps cooler, SEO hoses, WX3 wheels (in the summer) - Rest In Pieces 6/13/12 1630
\'83 Caprice Classic Wagon, 117k Rest in Pieces 10/23/05 1306
\'75 Caprice Classic Convt, 61K The original LT4 (400 SBC)
impala79 is offline
post #2 of 4 (permalink) Old 03-06-2012, 01:56 AM
B. Campbell's Avatar
Send a message via AIM to B. Campbell
I Simple part # is: "IS77" you will need that and antenna adapters (Metra part #'s: "40gm10" & "40gm10"), most audio shops will charge any where from $65-100 dollars to install a modulated aux piece like this and will try and tell you not too. Most likely they will say "just to swap the radio" - and they are correct... For the $250 your about to waste you are much better off swaping the radio as this option is only going to sound as good as your best FM station as it uses your factory antenna as your new "aux" connection. There is no part that I am aware of that works through the CD change port. You may be able to use a USA-Spec's PA11-GM45
http://usaspec.com/product.php?ProductID=25
as usa specs site lists it as a part available for the "1997" Impala SS lol....
That part runs about $180-200 and will give you the best sound as opposed to the modulated options from isimple that give you 3/4's of the volume this piece would...
In this case since you have no factory steering wheel controls or a factory touch screen nav (duh) you are needing to interface, so it is a complete waste of money. I only use these pieces in cars when its a cheaper option than a radio swap.
If you don't wanna ruin the factory look have an aftermarket one mounted in the glovebox or somewhere creative and use a RF remote after extending the ref repeater.
The best option and even one I have entertained is using the JL Clean-sweep
http://www.jlaudio.com/car-audio-system-expansion
I use the clean sweep and audio control equivalent pieces i'd say about once a month in an install where there is no way to replace the factory radio without bastardizing the cars dash, ex: 2010 Jag XK-R (billet trim all over the dash)
Please don't waste your money on the isimple or usa spec piece - your car deserves much better.
2nd Corinthians 4:16-5:8
B. Campbell is offline
post #3 of 4 (permalink) Old 03-06-2012, 11:26 AM
Wraith'SS's Avatar
I was thinking of going with one of these units.
Any thoughts people?
http://www.ebay.com/itm/Delco-MP3-In...item1c23abb7d5
'96 SuperSport DCM
My daily reminder of how much fun driving one of these cars 365 days a year really is!!
Subtle modifications, susp, lights, ign, tires, tune, cold air intk, etc. 100k and counting daily!
Wraith'SS is offline
post #4 of 4 (permalink) Old 03-06-2012, 12:04 PM
jimmyjam's Avatar
thats pricey. you can get one of those hus for ~$75 and do that mod for another $10 in parts
1996 Impala SS - DCM - LS swap in progress...
2006 Trailblazer SS - 402ci LS2, RWD 4L80 swap
jimmyjam is offline
