Best 6.5 component speakers for 300? - Chevy Impala SS Forum
post #1 of 35 (permalink) Old 03-17-2012, 11:19 PM Thread Starter
bighom20's Avatar
Whats up guys im looking to get some nice component speakers in a price range $150-$300. I plan on deleting my 4 6x9s i have in the rear and going with good components and a good sub, so I can get a good 2 channel amp as well.
94 Impala SS BBB-135k-Bagged on 20'' oasis-Sold
95 Impala SS DCM-Mostly Stock
ISSCA#2418
bighom20 is offline
post #2 of 35 (permalink) Old 03-17-2012, 11:54 PM
st95ss's Avatar
Talking
I have infinity 6x5 in my doors and 6x9's in the deck being run by a infinity 4 channel amp along with 2 P3 rockford fosgate 12 subs with a rockford fosgate amp pdb1000 and my system SSounds good to me bruh but other bruh's will chime in and give good advice also, hopes this helps, just my 2c
95 DCM Impala SS, G2 Cold Air Induction,G2 power pulley kit w/ v-belt ,G2 throttle body plate, G2 air foil,G2 Valve Cover Breather,pcmperformance tune, 160 thermostat,Borla Full Stainless Steel Exhaust, tri-y headers, 12 way Bonnie, air pump delete, 91 Caprice tailights SSittin on TIS 06's 22's
# 3,683 of 18,365
http://www.cardomain.com/ride/229728...ellville-ga-us
st95ss is offline
post #3 of 35 (permalink) Old 03-17-2012, 11:57 PM
96Caprice_SS's Avatar
I have some infinity reference 6.5 comps up front and single 12 in the trunk with the 6x9 delete. Doesn't "bang" but sounds great inside
"Trill workin tha wheel"
96Caprice_SS is offline
post #4 of 35 (permalink) Old 03-18-2012, 01:27 AM
Focal, Diamond, Rainbow, Image Dynamics..
heatman74 is offline
post #5 of 35 (permalink) Old 03-18-2012, 06:13 AM
ejschultz's Avatar
Think twice about Image Dynamics now. If you can find oldler ones BNIB, go for them. They sold to come Chinese company and I'm positive their quality will start to go down. Focal, Diamond, and Rainbow are good places to start. Check around for a set of Alpine SPX-17PROs too. They may go a tad over your $300 range, but they're nice speakers. I usually recommend Pioneer, but the TS-D1720Cs are going to be the only ones in your range. You could get their Stage 4 components, but they're well over what you want to spend. If you can find a set of TS-C720PRS components in that range or a little over, jump on 'em. They're great speakers. Check out some of the Hertz lineup and Hybrid Audio as well. Again, they may be a little more expensive, but if you want a killer front stage...
-94 Caprice Classic LS - system, Gary's wires, 200 amp alt, tint, first base/home plate delete, clear corners w/green parking lights, LTZ hood emblem, SS springs
-97 Grand Cherokee TSi - 4" IRO lift, OEM skids/hooks/hitch, sliders, 31s, rear locker, system, tint, cloth, clear corners, Magnaflow stuff
Refs: DesertDawg, 214Texas, QUICKSSILVER, SSon22s, MadMav, gary burton
ejschultz is offline
post #6 of 35 (permalink) Old 03-18-2012, 12:09 PM
I have older bostons and they're amazing even off just deck power. Look for a higher s/n ratio, 92 is pretty standard for components but 95 or even 98 are out there. Usually high power handling coils will be lower s/n but a higher s/n ratio means it takes less power to make more sound. From my searching, Boston makes the perfect blend or at least they used to a few years back.
i5racer is offline
post #7 of 35 (permalink) Old 03-18-2012, 10:01 PM
I just got a set of polk audio dxi6500.I havent had a chance to install them but have heard nothing but good things
Shttn89 is offline
post #8 of 35 (permalink) Old 03-19-2012, 12:06 AM
st95ss's Avatar
Talking
when you get them installed you know what to do lol
# 3,683 of 18,365
st95ss is offline
post #9 of 35 (permalink) Old 03-19-2012, 12:08 AM Thread Starter
bighom20's Avatar
I have now a jl audio 300/2 amp and was wondering can these components handle the amp, there called hertz hi energy hsk 165, they are are rated at 250 max and 125 rms each side. Anyone run these before? Or are there better components for the price $150?
ISSCA#2418
bighom20 is offline
post #10 of 35 (permalink) Old 03-19-2012, 04:02 AM
96WAGON's Avatar
Infinity Kappa's or if you could find them Soundstream SPL's (old school). Back when Soundstream was made in the USA, those were the chit!!
96 Caprice Wagon: LT1, Black exterior with ruby red inside, Soundstream sound, rollpan, Corvette dress, LT4 valve covers, Edelbrock headers, SRI cai, Spintech 6334 muffs, Dynomax stainless tips that exit behind wheels, H-Pipe, built tranny with Corvette servos, Hipro valve body & stall convertor, 9C1 rear disc w/ SS backing plates, Wildwood 1.5" rotors w/ 4 piston calipers in front, swaybars front & rear, Metco rear links, 20" Centerline Lancers with Sumitumo 255-35-20 shoes. 1 of 485 built!!
96WAGON is offline
