Speaker Problem - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 04-03-2012, 06:42 PM Thread Starter
Slayerdies's Avatar
Send a message via AIM to Slayerdies
Speaker Problem
Ok two part problem.
First I am not getting any audio for passenger rear speaker.
I even hooked up up spare speaker to connection at passenger front kick panel and am not getting signal there.
Second problem passenger front speaker blown.
Just want to know a good speaker to go with for replacement. I plan to put in a double din/system in few months so like to take front doors off just the one time to replace speakers.
96 BBB Impala SS
Auto Climate, F-Body EGR, Gary's Batt Cables, Break Bolts, 160hyperstat, TB Bypass, Home Depot Intake/Hockey Puck and SwissCheeseAirBox, Try Y Gen II's, Pypes Xpipe,,Dynomax UltraFlows, Sprints, C3extend with solid uppers, NitroDrop2s, TruTrac with 3.73s
Work In progress... On a tight budget
Parts Sitting In The Garage...
S-10 converter, Blazer overhead
Slayerdies is offline
post #2 of 2 (permalink) Old 04-03-2012, 09:43 PM
Try disconnecting the blown pass front speaker, if the voice coil is shorted it could be putting the head units internal a,pilfer into protect, thus the rear speaker output not working. Some head units have a separate left and right internal amp, this might be the case on yours: left side working but right side not due to the blown speaker. Let us know how you make out.
I use Memphis in all my setups, but go to a local shop you know or a friend recommends and listen to as many speakers as you can and decide what you like that is in your budget.
2002 VTX1800C - Muzzys exhaust, Hypercharger, Power Commander, custom paint,
1996 impala SS clone 22" Giovanna gabbs, flow master exhaust, intake, bagged
2007 Suburban - Daily Tank
bagnut is offline
