how to prevent fuel pump shorting out ? - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 04-11-2012, 12:14 PM Thread Starter
defdaboss's Avatar
been having problem with the fuel pump ever since upgrading the new sound system. seems like the ground might be burning out again. a quick and temporary fix is to bang the gas tank. going to replace the harness but can i cut the ground wire off the harness and run it straight to the frame for better ground?
defdaboss is offline
post #2 of 3 (permalink) Old 04-11-2012, 02:21 PM
Mr pogo's Avatar
http://www.racetronix.biz/itemdesc.a...%2D004&eq=&Tp=
Mr pogo is offline
post #3 of 3 (permalink) Old 04-19-2012, 08:40 PM Thread Starter
defdaboss's Avatar
this relay is similar to these starter kill relay. the power comes from the alternator and the ground for the fuel pump and relay to the frame. + to the relay for switch and the purple wire is left alone. this isnt hard to make ill give it a try.
