My Weird Head Unit - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 04-13-2012, 10:52 PM Thread Starter
Atlas Prime's Avatar
My Weird Head Unit
A while back I had an interesting problem.
My stereo would cut out in the middle of songs.
Just today I figured out that it was because I had too many speakers hooked to it.
I removed one (it was a stock one up front. Sounded like cloth slapping a plaster wall) and now it works rather well.
HOWEVER!
If I turn it up too loud, it still cuts out, and I assume this is to keep itself from breaking... itself.
My question:
Would an amp fix this problem?
This is probably a stupid question, however I will use it to springboard into my next one:
I'd like a 5 channel amp (for later addition of subwoofers and tweeters; at the moment I simply have pioneer 6x9s in the rear) and I'm not sure which one would be best for me. Any ideas from adept audio specialists?
1969 Chevy Caprice
Atlas Prime is offline
post #2 of 6 (permalink) Old 04-14-2012, 12:18 AM
Crime Scene 96's Avatar
To the best of my knowledge an amp wont fix it. It may make it worst, but dont qoute me on that.
I would check the settings on the box of your head unit to see if there are any sound cut outs at a certain level to protect hearing loss. I know it seems kinda dumb, but you can never tell with todays technology. Also, i would recheck all your wiring in the back of the head unit also.
1996 Chevy Impala SS BBB -
R.I.P. 4/15/2012
1996 Chevy Impala SS DGGM -
Replaced BBB on 4/30/2012
Crime Scene 96 is offline
post #3 of 6 (permalink) Old 04-14-2012, 06:14 AM
st95ss's Avatar
x2 on that bruh
95 DCM Impala SS, G2 Cold Air Induction,G2 power pulley kit w/ v-belt ,G2 throttle body plate, G2 air foil,G2 Valve Cover Breather,pcmperformance tune, 160 thermostat,Borla Full Stainless Steel Exhaust, tri-y headers, 12 way Bonnie, air pump delete, 91 Caprice tailights SSittin on TIS 06's 22's
# 3,683 of 18,365
http://www.cardomain.com/ride/229728...ellville-ga-us
st95ss is offline
post #4 of 6 (permalink) Old 04-14-2012, 10:15 AM
Mr pogo's Avatar
HOWEVER!
My question:
google "amp clipping", thats whats currently happening on yours.
if your current head unit has line level outputs it can be used to control an amp.
you may want to consult a car audio shop or peruse car audio magazines to see what state of the art choices are available for your budget.
Mr pogo is offline
post #5 of 6 (permalink) Old 04-14-2012, 10:29 AM Thread Starter
Thanks guys! Great info
1969 Chevy Caprice
post #6 of 6 (permalink) Old 04-22-2012, 06:48 PM
B. Campbell's Avatar
Send a message via AIM to B. Campbell
Word. Time for an amp and some real speakers! Do it right, you get what you pay for and higher end equipment holds its value and lasts considerably longer, especially with electronics, and in most cases is worth paying the costs for repairs 5-10 years down the line. Much like "classic cars".
2nd Corinthians 4:16-5:8
B. Campbell is offline
