SQ Set-Up - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 04-19-2012, 07:52 AM Thread Starter
95BLKSS's Avatar
SQ Set-Up
So I've just about got rid of all my old audio and have decided on new build. I'm going to end up running old school xtant amps.
Electrical
New alternator w/overdrive pulley and BIG3
2 New Optima Yellowtop D34/78
0 Gauge everywhere (2 runs to rear battery, one pos and one neg)
Highs/Mids - Diamond Audio 6.5" HEX (older version)
Diamond 6.5" Hex (older version) - May delete rear fill. not set
Subs - 2 Oldschool Eclipse 88120 (TC9 motors)
Interior Amp - Xtant x604 - Nice 4 channel
Sub Amp- Xtant x1001 - should put out around 1500 watts of clean pwer
Pics to come...
95 9C1/Impala SS Clone - Black Diamond Metallic, Ram Air Hood, Smoothie bumpers, Smoothed and Blacked out 91 Tails w/led sequential kit, Staggered 20" Torq Thrust IIs w/Pirellis, Dropped with intrax coils in front, moog coils in rear, 385 Stroker, Level 3 Trans, Richmond 3.90 rear end, bonneville seats, working on swapping Lloyd Elliot camshaft in... Always a work in progress
95BLKSS is offline
post #2 of 5 (permalink) Old 04-19-2012, 12:02 PM
WaTTsLOk187's Avatar
Send a message via AIM to WaTTsLOk187
What deck will you be using Or processing? Are you going to run active?
1996 Dggm Impala SS
CM Forged 355 with LT4 heads and Hotcam Installed by Phil, LTCC, 3:73's, Edge 3000 Stall Installed by Troy, Denny's DShaft, Tri-Y's, OBD1 Conv, Meziere Pump, Bilsteins, Hotchkis Springs, Finally Running Right PRICELESS!
WaTTsLOk187 is offline
post #3 of 5 (permalink) Old 04-19-2012, 12:54 PM Thread Starter
95BLKSS's Avatar
I'll be using a Kenwood Excelon KDC-x991...
Thinking about running active, need to read up on it though. I've never ran active crossovers... Barely experimenting with the whole car audio scene.
Any suggestions?
95BLKSS is offline
post #4 of 5 (permalink) Old 04-22-2012, 06:36 PM
B. Campbell's Avatar
Send a message via AIM to B. Campbell
I say give active a try, but if those HEX's come with passive crossovers you will probably prefer how that sounds, active is nice when you enjoy tuning your system for hours on end and your using drivers that don't have crossovers, but everyone's ear is different - never hurt to try and you can always go back to passive
those TC9 motor'd eclipses are great btw and they look slick
2nd Corinthians 4:16-5:8
B. Campbell is offline
post #5 of 5 (permalink) Old 04-25-2012, 08:01 PM
ejschultz's Avatar
I went active in my Caprice a couple years ago with my 800PRS. The main reason I did it was to fine tune my tweeters. I'm extremely happy with the way I was able to get everything sounding. It did take some time to get everything to where I thought it sounded good. I was almost ready to go back to a passive setup but decided to read a little more about tuning and TA on DIYMA.
-94 Caprice Classic LS - system, Gary's wires, 200 amp alt, tint, first base/home plate delete, clear corners w/green parking lights, LTZ hood emblem, SS springs
-97 Grand Cherokee TSi - 4" IRO lift, OEM skids/hooks/hitch, sliders, 31s, rear locker, system, tint, cloth, clear corners, Magnaflow stuff
Refs: DesertDawg, 214Texas, QUICKSSILVER, SSon22s, MadMav, gary burton
ejschultz is offline
