Auto dim function for headunit - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 06-02-2012, 01:30 PM Thread Starter
cadillac_rancher's Avatar
I've searched and was not able to find anything. Which wire can i splice into to use the auto dim feature of my headunit. My car is a 94 fleetwood brougham.
I noticed the lights on the climate control change when the headlights come on but I dont know which wire would control that. I think the Cadillac climate control is wired the same as the Roadmaster climate control if that helps.
94 DCM FWB V4P w/ sunroof
Intake, Exhaust, 280 XFI, NSA 1.5rr w/ Bullet Vs2700 Springs, Built 643 heads/intake, L67 32.2lb Injectors, Mild Trans, Edge 3600, SS Springs, Belltech Drop Shocks
Wrecked.......
94 DGGM Z28 M6
1962 Imperial Crown 4 door hardtop
cadillac_rancher is offline
post #2 of 4 (permalink) Old 06-02-2012, 03:04 PM
jayoldschool's Avatar
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink (if available) Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
jayoldschool is offline
post #3 of 4 (permalink) Old 06-03-2012, 11:49 PM Thread Starter
Thanks i'll take a look at this tomorow, Would these wires be in the trunk though? Or in the small connector that was plugged into the headunit in the dash?
Wrecked.......
94 DGGM Z28 M6
post #4 of 4 (permalink) Old 06-15-2012, 03:22 PM Thread Starter
For anyone wondering I ended up splicing into the ash tray light power wire and its works great.
Wrecked.......
94 DGGM Z28 M6
