Rear speaker out. Read whole story please - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 06-04-2012, 08:45 PM Thread Starter
Slayerdies's Avatar
Send a message via AIM to Slayerdies
Ok. About 6 months ago my passenger side rear speaker started to crackle then quit.
I switched two rear speakers side to side and both speakers themselves work.
Figured head unit or another speaker causing rear to not work.
I replaced all four speakers. Pass rear still wont get signal.
here is where it gets weird. I plug in after market radio and pass rear works but driver rear dont.
If i reverse the wires for left n right rear on either headunit i can get both speakers to work just not both same time.
I am stumpid here.
Is there a amp or passover behind the dash or something?
96 BBB Impala SS
Auto Climate, F-Body EGR, Gary's Batt Cables, Break Bolts, 160hyperstat, TB Bypass, Home Depot Intake/Hockey Puck and SwissCheeseAirBox, Try Y Gen II's, Pypes Xpipe,,Dynomax UltraFlows, Sprints, C3extend with solid uppers, NitroDrop2s, TruTrac with 3.73s
Work In progress... On a tight budget
Parts Sitting In The Garage...
S-10 converter, Blazer overhead
Slayerdies is offline
post #2 of 7 (permalink) Old 06-05-2012, 06:15 PM Thread Starter
Slayerdies's Avatar
Bump...
96 BBB Impala SS
post #3 of 7 (permalink) Old 06-06-2012, 09:20 AM Thread Starter
Slayerdies's Avatar
Bump...
96 BBB Impala SS
post #4 of 7 (permalink) Old 06-07-2012, 01:26 PM
SignatureSeriesOwner's Avatar
Send a message via MSN to SignatureSeriesOwner
AFAIK, the radio is also the amplifier.
It could be bad capacitors in the amplifier of the factory radio, one would need an ESR meter to check this.
As far as it still acting up with the aftermarket, it could have a similar issue, or there may be an issue with one of the harnesses and/or wiring on that side. Could be pinched and shorting somewhere.
1994 Lincoln Town Car, Signature Series, 4.6L V8, fully loaded, 150K -
1993 GMC Sierra K1500, SLE, 5.0 V8, Auto, 129K -
1993 GMC Sierra C2500, SL, 4.3L V6, 5 Spd, 255K - Sold.
1977 Lincoln Continental Town Car, 7.5L V8, Auto, 77K -Sold.
1995 Chevrolet Caprice Classic, 4.3L V8, 156K -Sold.
SignatureSeriesOwner is offline
post #5 of 7 (permalink) Old 06-08-2012, 02:07 AM
cadillac_rancher's Avatar
What is your headunit grounded to, the wiring harness or the chassis?
94 DCM FWB V4P w/ sunroof
Intake, Exhaust, 280 XFI, NSA 1.5rr w/ Bullet Vs2700 Springs, Built 643 heads/intake, L67 32.2lb Injectors, Mild Trans, Edge 3600, SS Springs, Belltech Drop Shocks
Wrecked.......
94 DGGM Z28 M6
1962 Imperial Crown 4 door hardtop
cadillac_rancher is offline
post #6 of 7 (permalink) Old 06-09-2012, 10:06 PM Thread Starter
Slayerdies's Avatar
I guess factory ground. It is an intact wiring harnes.
i am gonna mess with it some more tomorrow.
96 BBB Impala SS
post #7 of 7 (permalink) Old 06-10-2012, 01:04 PM
Some of the factory grounds arent the best, I would ground it to the chassis down by the kick panels. My stock radio was doing the same thing. When I put in my new headunit I grounded it to the chassis and without touching anything else all the speakers worked.
Wrecked.......
94 DGGM Z28 M6
