How Much Sound deadener needed for door? - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 06-23-2012, 01:39 AM Thread Starter
As title states I Own a 1995 DCM work In progress, Going thru a whole audio overhaul. I am having some 6.5 image dynamics and want to get some either fatmat or raamat in there. I dont want to buy too much so I was hoping a forum member knew exactly how much was needed for doors.
NintyFive is offline
post #2 of 6 (permalink) Old 07-12-2012, 10:53 PM Thread Starter
Wow all you audio heads and have no idea of how much deadner is needed for doors?
post #3 of 6 (permalink) Old 07-12-2012, 11:16 PM
That's because everyone is thinking the same thing as this:
Get out your friggin' tape measure and figure it out.
Plus, you don't say - 2 doors, 4 doors, front, back, buying a roll or squares, etc. OK, it's probably 2 front doors, but "a whole audio overhaul" could mean anything.
grandpas wagon
grandpas wagon is offline
post #4 of 6 (permalink) Old 07-14-2012, 10:24 AM
Coolwazabi's Avatar
16-20 sq ft
Flowmaster 50 Series w/ 4" Tips
DDM Tuning 55w 5000k HID's
15" Custom Audioque HDC3, 35hz
2x Audiopipe 1800d's
Kenwood KDC-X996
Big 3 Upgrade
5901 Viper Alarm w/ Remote Start
1995 Chevy Caprice 4.3L L99
Nashville
Coolwazabi is offline
post #5 of 6 (permalink) Old 07-14-2012, 03:25 PM
AZ Roadmaster's Avatar
As much as it takes!
[/SIGPIC]92 RMS, daily driver, project car, Eibach springs, Bilstein shocks, BMR rear upper and lower control arms, BMR front and rear sway bars, Dick Miller braces, Spohn spherical ft end links, fabricated ft sway frame support, ROH wheels with Nitto tires, replaced upper and lower control arms and all steering linkages and reman box. reprogramed ecu, tb spacer, adj. fp reg, cold air intake, electric fans, pully kit, SS rear with posi 3:73's Next big brake kit!
AZ Roadmaster is offline
post #6 of 6 (permalink) Old 07-14-2012, 05:06 PM
fuzzcar's Avatar
According the www.sounddeadenershowdown.com could get away with as little as 25% coverage if you put the deadener in the middle of the panel and some behind the speaker, if cost is really a consideration. Personally I plan on doing about 75% with deadener in the doors because they are a major noise source, I also plan on 99.9% coverage with a sound barrier for sound isolation which makes my music sound better.
fuzzcar is offline
