92 double din? - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 07-09-2012, 07:28 PM Thread Starter
92 double din?
is it possible to put a double din touchscreen in a 92 wagon?
coast 2 coast is offline
post #2 of 6 (permalink) Old 07-10-2012, 10:23 PM
AZ Roadmaster's Avatar
Not without a LOT of work & custom dash panels. I contemplated doing it on my '92 RMS. I have a spare dash panel to play with but not enough time. I would change it from a one piece to a 2 piece to gain the room, then mold to fit and recover with woodgrain vinyl to match.
[/SIGPIC]92 RMS, daily driver, project car, Eibach springs, Bilstein shocks, BMR rear upper and lower control arms, BMR front and rear sway bars, Dick Miller braces, Spohn spherical ft end links, fabricated ft sway frame support, ROH wheels with Nitto tires, replaced upper and lower control arms and all steering linkages and reman box. reprogramed ecu, tb spacer, adj. fp reg, cold air intake, electric fans, pully kit, SS rear with posi 3:73's Next big brake kit!
AZ Roadmaster is offline
post #3 of 6 (permalink) Old 07-11-2012, 01:43 AM
rematar's Avatar
This thread may help a bit.
05 magnum rt with srt8 300 front
95 dcm wb4 rmw funeral car from fred - sold
93 white woody rmw - sold
rematar is offline
post #4 of 6 (permalink) Old 07-16-2012, 02:55 PM
mafiacustomz's Avatar
Send a message via Yahoo to mafiacustomz
I plan on putting a double din touchscreen in my 91 caprice it dont look to be to hard. I have put a double din touchscreen in a 91 caddy it wasnt to hard.Click image for larger version
Mafia Customz
91 Caprice classic lo3 305 tbi headers and wires.
Suicide back doors shaved everything.
Next 5.3 ls swap.
mafiacustomz is offline
post #5 of 6 (permalink) Old 09-20-2012, 07:51 PM
91LowLow's Avatar
I want to put a double din in my 91 caprice what do i need to cut or mold to make it fit flush in the dash I already have an extra dash panel panel to fill in any gaps that maybe left after cutting also does anyone know where I can buy a set of fiberglass door panels with speaker cut outs front and back.
88 Caprice (Sold)
93 Caprice (Sold)
91 Caprice(Current)
88 Cutlass (Sold)
04 Monte Carlo SS (Sold)
06 300 Limted (Current)
91LowLow is offline
post #6 of 6 (permalink) Old 09-20-2012, 11:47 PM
Crtlv's Avatar
ive seen a few 91s with double dins and it seems fairly straight forward,Use a kenwood Double din sleeve as a rough guide to get it in and make it look flush.as far as door pannels make them yourself it isnt hard and the cost your saving lets you be really custom with your install,Most of the premade door pannels your gonna find are going to need ALOT of prep work and sanding which equals alot of labor time and cost that could have been saved if you did the work from the start yourself
Crtlv is offline
