So it starts - Chevy Impala SS Forum
post #1 of 25 (permalink) Old 09-10-2012, 03:12 PM Thread Starter
thebigbadWOLF's Avatar
So it starts
I am not doing the car-puter on this build but it has began.
Sent from my PG86100 using AutoGuide.Com Free App
Cali-SS
thebigbadWOLF is offline
post #2 of 25 (permalink) Old 09-10-2012, 10:12 PM
Crtlv's Avatar
running 4 punch p1s a hifonics amp "Looks like the 2000" and several infinity kappas.Whats your headunit?Going sealed box or blow thru?ive never been a fan of the infinity line but the kappas do have a smooth sound to them for a decent budget.Btw what carputer setup were you building?Ive done several and always love to read up on how others tackle the beast so to speak
Crtlv is offline
post #3 of 25 (permalink) Old 09-10-2012, 11:34 PM Thread Starter
correct, correct,
i have always liked the kappa's they are very "bright"
alpine CDA 9886R
it will be a box inside of a box, sealed box, firing into a chamber thats ported to the back dash.
Cali-SS
post #4 of 25 (permalink) Old 09-10-2012, 11:42 PM
Crtlv's Avatar
ok so its a blow thru 4th order box.Not bad just remember if your using the P1s that rockford was never really good with there displacement figures on the subs so make sure to add 10% for possible error and dont do the usual adding the port dimentions x4 because your using 4 subs.Use the figures for 2 subs and add more to your rear section.Bass box pro works very well for calculations on this type of box FYI
Crtlv is offline
post #5 of 25 (permalink) Old 09-10-2012, 11:44 PM Thread Starter
are you coming to WCG?
add 10%?
no real reason to using the p1's beyond i got all 4 for like 80$. i figured **** it, normally i am a JL guy (old school JL anyways)
Cali-SS
post #6 of 25 (permalink) Old 09-10-2012, 11:48 PM
Crtlv's Avatar
yea ill be at WCG, The bad imp and 2 other cars that ive put together will be there so im gonna always be near,Besides vegas is my home how can i miss a get together like this!!!
Crtlv is offline
post #7 of 25 (permalink) Old 09-10-2012, 11:50 PM Thread Starter
o ya no **** now i recall your name, i rememebr seeing you doing bad imps system...
so tell me more about this 10%
Cali-SS
post #8 of 25 (permalink) Old 09-11-2012, 12:05 AM
Crtlv's Avatar
if your Ported internal volume Minus driver displacement is supposed to be 1.75 cf corrected,Add 10%to that figure per sub and then allot that to the REAR chamber of your box ie your rear section will be the one with the port firing thru the deck then board subs then front wall.you should have 20%more space in the back of the box than the front .Heres the math,Subs are 1.75 ported and corrected "Again just a number im using "
Plus 10%makes required space 1.925x4 subs total 7.7 20%of that is 1.54.half of the total box is 3.85 add 1.54 IE your 20%extra for rear chamber your rear chamber is going to be roughly 5.39 abouts and the balance in the front of the subs
Again ive gotten into math arguments before about this yet every time i have applied this to any 4th order box i can always tune lower and at a more stable freq than if i didnt.Just works for me and its the reason why i stay away from blow thru boxes my head hurts after all the adding and subtraction i have to do
lol
Crtlv is offline
post #9 of 25 (permalink) Old 09-11-2012, 12:12 AM
Crtlv's Avatar
essentially your making the figures 10%larger and then building the divider in your box to make it 60/40 with the 60 %of the total volume in the section that carries the port
Crtlv is offline
post #10 of 25 (permalink) Old 09-11-2012, 03:01 AM
impreSSive's Avatar
Thumbs up
Originally Posted by crtlv View Post
yea ill be at wcg, besides vegas is my home how can i miss a get together like this!!!
sweet!!! :d
95 BBB (4SSALE)
96 DGGM
96 DCM
95 DGGM WAGON
96 BBB - LS BEASST
Cali-SS
ISSCA#2212
impreSSive is offline
