1996 roadmaster audio questions - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 10-02-2012, 07:05 PM Thread Starter
What installation kit can be used to put a aftermarket cd player in my roadmaster dash? What kinda speakers can be used in the doors?
atcrider1 is offline
post #2 of 10 (permalink) Old 10-05-2012, 11:46 AM Thread Starter
???? nobody has a cd player in their roadmaster?
post #3 of 10 (permalink) Old 10-05-2012, 09:40 PM
rematar's Avatar
I believe I have seen some threads about replacing the head unit, but can't find them.
The roadmasters with electronic climate control use circuitry in the audio head unit to dim the climate control. When you go to an aftermarket unit your climate control is on full daytime brightness all the time, which drove me nuts.
Several 90's Buick models had the same double din head unit. I pulled one from a 98 Park Avenue, it seems to have a better CD player. I have seen some Buicks with the same kind of head unit and steering wheel as ours with controls on the steering wheel - if you would consider that any kind of an upgrade.
Here is a thread about front door speakers.
05 magnum rt with srt8 300 front
95 dcm wb4 rmw funeral car from fred - sold
93 white woody rmw - sold
rematar is offline
post #4 of 10 (permalink) Old 01-21-2013, 03:28 PM
that should be pretty easy to overcome by wiring into the illumination of the car. ive not tried myself but you should be able to tap the dimmer wire on the radio and hook it to climate controls.
nekkidhillbilly is offline
post #5 of 10 (permalink) Old 01-21-2013, 03:29 PM
other than that it should be the same as swapping a radio and speakers in any other car.
post #7 of 10 (permalink) Old 01-21-2013, 03:42 PM
post #8 of 10 (permalink) Old 01-21-2013, 05:38 PM
coltonx3's Avatar
auto zone has what you need thats were i got mine for my 95 caprice just type in harness
coltonx3 is offline
post #9 of 10 (permalink) Old 01-21-2013, 09:12 PM
rematar's Avatar
Originally Posted by nekkidhillbilly View Post
...tap the dimmer wire on the radio and hook it to climate controls.
Unfortunately no, the electroflourescent (?) display requires the dimmer that is in the radio.
rematar is offline
post #10 of 10 (permalink) Old 01-22-2013, 12:01 PM
i see that its pulse width modulator. i posted how to make it work. or someone could build one.
