Subwoofers - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 11-02-2012, 01:13 PM Thread Starter
Subwoofers
how do you guys select your subs?/ do you do it by db or RMS power?? I have seen a couple of threads and everyone is recommending subs with 86-89 db rating. I try to go for 92+db and at least 600RMS what do you guys think?
96SpaceShip is offline
post #2 of 6 (permalink) Old 11-03-2012, 02:03 PM
db vs RMS isn't a good comparison. Db (decibels) measures how sensitive your sub is, and is more of how you pair your subs with your amp. RMS is how much power the amp can deliver/the sub can take constantly. You could buy a 1000W RMS sub, but if you only have a 200W RMS amp it's not going to sound that good. On the other hand, you could get a 200W RMS sub and a 1000W RMS amp and you have a good chance of blowing your sub if you turn it up too much. It's best to get an amp that's RMS rating is around 20% stronger than your sub (ie - 250W amp with a 200W sub), then turn the gain on your amp to about 80%. That way, you won't get much distortion from the amp huffing and puffing to push out max power to your sub, and your sub will be playing at it's max power constantly. Distortion is WAY worse for any speaker than playing it too loud could ever be.
if you want, you can put up some options that you're looking at and I can let you know what a good pair can be. Or, you can give a price range you want to stay in and i (or anyone else) can suggest a few good pairings. You'll have to let us know what you're looking for (boom vs. sound quality) first tho...
psburtis is offline
post #3 of 6 (permalink) Old 11-03-2012, 04:09 PM Thread Starter
here is what i am looking at
a pair of 12" Audio Bahn AW1200J 700 watts RMS with an MTX Thunder Elite 801D wired in parallel
post #4 of 6 (permalink) Old 11-04-2012, 12:35 PM
from the looks of it, that should be a pretty good setup. Both the subs are 700W RMS a piece, and the amp puts out 800W RMS at 2 ohms, which you'll get if you wire them in parallel. If you turn the gain on your amp to around 85%, you can turn your subs up as loud as your stereo can go and you shouldn't be in any danger of damaging them. Good luck!
Brutus
1995 DCM 9C1/LT1 - Light Mods to engine and trans, 373 Auburn Posi, lowered 2", Borla cat-back exhaust, HyperTech Chip (from previous owner, don't judge)
psburtis is offline
post #5 of 6 (permalink) Old 11-04-2012, 02:10 PM
Coolwazabi's Avatar
smh.. yeah don't do that. you'll have to tune your amp in accordance with the preamp of you deck.
Flowmaster 50 Series w/ 4" Tips
DDM Tuning 55w 5000k HID's
15" Custom Audioque HDC3, 35hz
2x Audiopipe 1800d's
Kenwood KDC-X996
Big 3 Upgrade
5901 Viper Alarm w/ Remote Start
1995 Chevy Caprice 4.3L L99
Nashville
Coolwazabi is offline
post #6 of 6 (permalink) Old 11-04-2012, 10:44 PM
Look into an ddm1 on the smd forum or an o scope. Good rule of thumb would be to figure ur preamp volts off ur headunit and turn the gain knob to the coresponding voltahe on ur amp. That will get u close. When in doubt go with the lesser amount. May take time qithout an o-scope or ddm1 but be patient.
96 Impala SS
142,989
What does it matter anymore?
02 7.3 drw 350. It pulls really heavy stuff.
2015 Camry xse is my new daily. It has electric steering!!!!
M0U35Y's_SS is offline
