front door speakers biggerthan 6.5? - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 12-11-2012, 10:19 AM Thread Starter
fuzzcar's Avatar
Anyone running them? Do they fit under the door panel?
fuzzcar is offline
post #2 of 10 (permalink) Old 12-11-2012, 03:54 PM
350
350's Avatar
Send a message via AIM to 350
I know I saw a while back people running 6x9's, I think the thing to watch out for is the depth more than anything, larger speakers tend to also be deeper. I can't see why an 8" round wouldn't fit but it would have to be very shallow, or you'd have to keep the windows up.
95 DGGM SS. Cam and headers, boring stuff, classic tags, garaged
15 Durango R/T AWD, Fiat with a Hemi and 8 gears
15 Charger SXT AWD
350 is offline
post #3 of 10 (permalink) Old 12-25-2012, 08:47 AM
st95ss's Avatar
didn't sharp96ss have bigger door speakers, I wanna say yes
95 DCM Impala SS, G2 Cold Air Induction,G2 power pulley kit w/ v-belt ,G2 throttle body plate, G2 air foil,G2 Valve Cover Breather,pcmperformance tune, 160 thermostat,Borla Full Stainless Steel Exhaust, tri-y headers, 12 way Bonnie, air pump delete, 91 Caprice tailights SSittin on TIS 06's 22's
# 3,683 of 18,365
http://www.cardomain.com/ride/229728...ellville-ga-us
st95ss is offline
post #4 of 10 (permalink) Old 01-19-2013, 08:58 PM
Smile
you can fit anything lol
vader ss is offline
post #5 of 10 (permalink) Old 01-24-2013, 10:10 PM
are those speakers or bongo drums under that stretched out fabric?
1986 fleetwood brougham 66k original miles. chevy 350/ BTO 200r4 swap. pypes dual exhaust. bravada buckets and console. buick turbines next up: lower it!
1983 buick lesabre "the pimpmobile" 68k bone stock
2000 GMC safari explorer high top conversion van. 192k on body, 179k on 1997 4.3 "Z" motor
previous vehicles
1987 chevy silverado "the beast" 115k motor donor.
1991 olds cutlass cruiser wagon. 180k. 3300 with high flow injectors
cadillac kevin is offline
post #6 of 10 (permalink) Old 01-27-2013, 11:43 AM
my question is why would you want bigger. you subs handle the bass so i dont see an advantage if running more than 4 mids or highs.
nekkidhillbilly is offline
post #7 of 10 (permalink) Old 01-27-2013, 02:26 PM Thread Starter
fuzzcar's Avatar
Its more about sound quality and producing good mid-bass. If you try to make your subs play the mid-bass its obvious that its coming from the rear of the car and could be muffled and/or out of time alignment with the music that the front speakers are playing.
A lot of 6.5"s stuggle to put out some serious midbass thump, the bigger the speaker the easier (and usually cheaper) it is to do.
After looking. I think I could have stuffed an 8" speaker in the door. The issue is with the backspacing and having to use thick spacers and modify the door panel.
Instead I just got some 6.5's I'll try them first.
fuzzcar is offline
post #8 of 10 (permalink) Old 01-28-2013, 12:11 AM
i had a 8 in the front doors with a wood ring (spacer) behind the speaker. i did have to cut the metal a bit since i was using a 8'' bayma. the magnet was hitting a bit. but once i put the panel back on it looked stock.
vader ss is offline
post #9 of 10 (permalink) Old 01-28-2013, 12:15 AM
cadillac kevin-LOL those are 10'' ev's and that is custom stitching.
vader ss is offline
post #10 of 10 (permalink) Old 02-10-2013, 11:58 AM
a high wattage 6.5 will accomplish that better
