running dual 0 gauge?? - Chevy Impala SS Forum
post #1 of 14 (permalink) Old 01-31-2013, 11:23 AM Thread Starter
Coolwazabi's Avatar
I have them currently running under the car but want to drill the firewall and move them under the carpet. Where in the firewall should I or have you done so?
Flowmaster 50 Series w/ 4" Tips
DDM Tuning 55w 5000k HID's
15" Custom Audioque HDC3, 35hz
2x Audiopipe 1800d's
Kenwood KDC-X996
Big 3 Upgrade
5901 Viper Alarm w/ Remote Start
1995 Chevy Caprice 4.3L L99
Nashville
Coolwazabi is offline
post #2 of 14 (permalink) Old 01-31-2013, 11:48 AM
Mr pogo's Avatar
theres a sweet spot several inches under the heater on the passenger side firewall.
its flat and no harnesses or hoses in the way and room for a drill.
if you dont see it, its been mentioned before so search should find it.
Mr pogo is offline
post #3 of 14 (permalink) Old 01-31-2013, 12:08 PM
Kilgore's Avatar
ya that's what I did. on the passenger side I drilled a hole and put a rubber grommet in it then ran the wire through that
96 impala ss 48k
97 cbr-1100xx 22k
95 caprice 62k
Kilgore is offline
post #4 of 14 (permalink) Old 01-31-2013, 12:26 PM
Am not a fan of the grommet method. Do it right,and use a bulkhead connector. Maybe,people get away with running cable through sheet metal. The consequences associated with a failure of this practice are HUGE.
post #5 of 14 (permalink) Old 01-31-2013, 12:40 PM
juniorwatson's Avatar
Don't suppose you have a manufacturer or P/N handy do ya?
Great idea by the way!
juniorwatson is offline
post #6 of 14 (permalink) Old 01-31-2013, 12:55 PM
Just google "bulkhead connector" and you will find a bunch. Companies like Grainger and MSC have them.
I got some from Eastwood that were very nice and had a rubber internal that would cinch down over the wire as you tightened the connector to seal out the elements.
post #7 of 14 (permalink) Old 01-31-2013, 01:01 PM
Yeah I did that right after posting (Duh on my part) and found some thru McMaster-Carr & Grainger as well.
post #8 of 14 (permalink) Old 01-31-2013, 05:18 PM
Bigdawg70's Avatar
Just bought one for a race car was 2.50 from the warehouse would work perfect for what your doing.
Always a work in progress
Bigdawg70 is offline
post #9 of 14 (permalink) Old 02-05-2013, 03:37 PM
thanks for bulkhead connector idea never seen them... I worked on a truck two weeks ago, the power wire had been burned up by the exhaust manifold...
viperrgh2 is offline
post #10 of 14 (permalink) Old 02-05-2013, 08:33 PM
Knight703's Avatar
im about to start hooking up my system and this is one the questions I had as well.
you plan on running two 1/0 gauge wire can I ask what your running two for.
two amps? let me know interested
I was planning on doing the big 3 then running 4 gauge back to the amp.
but o gauge to the back/trunk doesnt sound bad
and are you running them under the plastic trim/door or directly under the carpet.
Knight703 is offline
