Speaker recommendations - 6.5 fronts - Chevy Impala SS Forum
post #1 of 66 (permalink) Old 02-12-2013, 08:49 AM Thread Starter
I will be updating my sound system very soon. I'm not looking to do a lot like add amps or woofers. Just looking to step up my old and outdated receiver as well as go with some 6.5's up front.
I have the mount plates for adding the 6.5" round speakers up front but not sure which to go with. I may just get a combo speaker that has the tweeter and all built in. BUT....I was also looking at the Component Speakers that have a 6.5" woofer and then a separate tweeter, usually 1" unit that can be surface mounted or recessed.
What have you guys gone with in a 6.5 arrangement? Did you get the all in one or did you do the component setup? If component, did you mount the tweeter to the same board as the woofer or did you mount it up high somewhere and where how did you mount? If I go this route, I'm either thinking of putting the tweeters up on the a pillar or maybe on the little plastic door trim that. Covers the side mirror nuts.
Just looking for some ideas and what you think sounds better a component setup or the all in one speaker.
post #2 of 66 (permalink) Old 02-12-2013, 09:27 AM
350
350's Avatar
Send a message via AIM to 350
http://www.customspeakerpods.com/Fro...00-00-01-A.htm
That's what I use. On my old Caprice I cut a small hole near the top of the panel and had them in there. Components sound much better than a coaxial (all in one) but if you're not gonna run an amp you might be better off with a drop in coax. I remember reading somewhere a while back that you either want the tweeter within a few inches of the speaker or more than a foot apart otherwise it messes up the staging. My last two vehicles have had tweeters in the dash which gives a really nice front stage.
95 DGGM SS. Cam and headers, boring stuff, classic tags, garaged
15 Durango R/T AWD, Fiat with a Hemi and 8 gears
15 Charger SXT AWD
350 is offline
post #3 of 66 (permalink) Old 02-12-2013, 11:50 AM Thread Starter
Thanks for the link, but I dont really want to do anything to the factory door panels. The mounts I just got will fit under the Door panel in the stock location and allow you to mount the 6.5's. I like these cause they are hidden under the stock panels. Just want to get a little better sound without butchering up too many stock parts and keeping it fairly simple.
From some reading I did on Crutchfields site, they recommend that you mount the tweeters at Shoulder height. A lot of the newer cars typically have these mounted on the A-Pillar or at the top of the door. I have no problem cutting up an A-pillar or door trim since I have extras if I ever go back to stock.
Thanks....Anyone else?
Maybe have some pics of what you used for some larger front speakers and if you went with seperate tweeters, where you mounted them.
post #4 of 66 (permalink) Old 02-12-2013, 04:11 PM
fuzzcar's Avatar
I would not mount them to the spacers in the doors. Tweeters play higher frequencies, which are very directional. You want them pointed at your ears as best you can.
fuzzcar is offline
post #5 of 66 (permalink) Old 02-12-2013, 06:17 PM Thread Starter
That's what I was thinking based on what I see in new cars and what Crutchfield recommended which was "shoulder height".
It looks like the plastic trim panel on the door that covers the side mirrors might be a good spot or somewhere on the Apillar. I thought about the top of the door panel, but I really don't want to cut up my otherwise perfect door panels.
post #6 of 66 (permalink) Old 02-12-2013, 09:00 PM
iowaSSfan's Avatar
Considering the same thing as you 4DoorSS. Im leaning towards componets as well.
iowaSSfan is offline
post #7 of 66 (permalink) Old 02-13-2013, 12:57 AM
Knight703's Avatar
same here looking for advice as well.
Knight703 is offline
post #8 of 66 (permalink) Old 02-13-2013, 09:11 AM
iowaSSfan's Avatar
I thought about getting this. http://www.customspeakerpods.com/Ash...00-00-05-A.htm
Then mounting two tweeters in it aimed at driver and passenger, and keep the center open for switches. What you guys think about that?
post #9 of 66 (permalink) Old 02-13-2013, 12:34 PM Thread Starter
Guys, I'm leaning toward the componet setup myself. It looks pretty straightforward, but if I do I will document it and take some pics. Might be a little while before I get to it...still got Brakes to do, Twilight Sentinel Install, a few other things and then the stereo and speakers.
IOWASSFAN - I like the idea and dont see why that wouldnt work. Just a little longer to run the wires or crossover circuit to the woofers.
Not sure it would be for me though. I like things more subtle and wouldnt want to get rid of the ashtray or disturb the clean lines of the dash panel....but that is just MY preference.
post #10 of 66 (permalink) Old 02-13-2013, 04:19 PM
fuzzcar's Avatar
I dont like that idea either. Your taking sounds that are meant to be coming from the same vicinity as the midbass speaker and moving them to the center, with both tweeters closer to each other than they are their respective mid. Maybe it would be alright if you were running them on a seperate center channel. But you would still want tweets for your left and right.
I'm dealing with a similar dilemma, heres what I considered options:
1. The custom speaker pods "door pods". My concerns with these are mostly due to the flimsy door panels. If I were to use these I would make considerable effort to strengthen and better mount the door panels. I dont want the panels absorbing a ton of viberation from the speakers and rattling.
2. Mount the 6.5's in the door with a custom spacer and mount the tweetersin the A pillar area. Similar to this:
http://www.diymobileaudio.com/forum/...q-install.html
3. The final option I am considering is scrounging some door bezels froma Buick Roadmaster with the concert II sound package and mount the tweeter to that. But you would have to do something about the mirror adjuster on the driverside bezel of the caprice/impala.
Right now I'm pretty set on going with option 2.
fuzzcar is offline
