Subwoofer?? 4-Ohm? or 2-Ohm? - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 02-20-2013, 07:57 AM Thread Starter
100SpokeRiderz's Avatar
If Im only going to run one subwoofer would I be better off getting a 4-Ohm sub or a 2-Ohm sub?
(I have not got a Amp yet, I will get that after I order the sub)
100SpokeRiderz is offline
post #2 of 10 (permalink) Old 02-20-2013, 08:30 AM
350
350's Avatar
Send a message via AIM to 350
Depends on the amp, but if you're deadset on just running one, get a 2 ohm one or a dual voice coil 4 ohm which you can wire to 2 ohms to get the max power out of your amp. If you think you might want some growing room, go 4 ohms and add a second sub later. Also what size are you going with? If you're going with a 15" you'll probably be fine with 1 sub, but we do have large trunks if it's 12's or 10's you'll probably wish you got two.
95 DGGM SS. Cam and headers, boring stuff, classic tags, garaged
15 Durango R/T AWD, Fiat with a Hemi and 8 gears
15 Charger SXT AWD
350 is offline
post #3 of 10 (permalink) Old 02-20-2013, 09:44 AM Thread Starter
My plan is to go with one 15" sub for the first stage of my system I was thinking about a Alpine Type S.
Right now I have a Basic Alpine deck that only has one set of Sub RCA's & some Kicker 6-1/2" & Kicker 6X9's running on deck power. I would like to add some bass to round out the system without drowning out the highs.
One sub, one amp, a deck, & 4 speakers is all I need for now because I want to build the rest of the car (paint,interior, rims, ect.ect.) When its time to upgrade the audio again I will replace everything & start from scratch but for now I want to keep things Low wattage untill I can do the BIG 3 upgrade & High Quality Sound Damping Material
post #4 of 10 (permalink) Old 02-20-2013, 10:04 AM
350
350's Avatar
I've ran 3 different sub amps, 300, 500 and 800 watt with no issues and everything stock. I later did upgraded battery cables but I'd think if you stay under 1000 watts everything should be fine.
15 Charger SXT AWD
350 is offline
post #5 of 10 (permalink) Old 02-20-2013, 10:52 AM
Barbarossa's Avatar
Send a message via AIM to Barbarossa Send a message via Yahoo to Barbarossa
Do you currently have an amp for the sub?
if not...
I would personally Get a Mono (Single channel) amp that is 2 ohm stable (D class 1000 watt, what is the 15" alpine rated for?); and get a 2 ohm 15" sub.
Then when you change to (2) subs, get two 4 ohm subs, and wire them in series showing the amp a 2 ohm load.
1996 DCM Impala SS
14.38 @ 93.48
Build Date: 1996-12-05
ISSCA # 2360
Barbarossa is offline
post #6 of 10 (permalink) Old 02-20-2013, 11:11 AM Thread Starter
if not...
I dont have a Amp yet I was gonna order one after I get my sub & here are the subs I was looking at
http://www.sonicelectronix.com/item_...-SWS-15D4.html
or
http://www.sonicelectronix.com/item_...-SWS-15D2.html
post #7 of 10 (permalink) Old 02-20-2013, 12:05 PM
Barbarossa's Avatar
Check out this for wiring diagrams.
http://www.crutchfield.com/S-QRmuXsl...rs_wiring.html
Alpine SWS-15D4
power handling: 150-500 watts RMS (250 watts per coil)
peak power: 1,500 watts
frequency response: 24-200 Hz
dual 4-ohm voice coils
[email protected] with mono 2 ohm amp
Alpine SWS-15D2
dual 2-ohm voice coils
[email protected] with mono 4 ohm amp
Your eventual upgrade?
2 single Voice Coil (SVC) @ 4 ohms with mono 2 ohm amp.
I'd probably amp it with something like this:
Or play nice with it and over power it with this: (until you get better dual subs)
Of course I wouldn't be going Alpine then, so I wouldn't pick alpine as the amp brand. (Myself)
If it were me I'd do a single 12 JLW6:
power range: 150-600 watts RMS
peak power handling: 1,200 watts
frequency response: 20-200 Hz
With this amp:
Bass Processor:
and a capacitor:
1996 DCM Impala SS
14.38 @ 93.48
ISSCA # 2360
post #8 of 10 (permalink) Old 02-20-2013, 01:23 PM Thread Starter
Alpine SWS-15D4
Alpine SWS-15D2
With this amp:
Bass Processor:
and a capacitor:
Thanks 4 the info I like JL Audio Ive had them in the past in a few cars but when its time to upgrade from this first system I think I wanna try DC Audio or PSI subs but for now I just wanna keep it simple & do one 15" subs to bring out the 4 kicker speakers that running off deck power thats in there now that way I have a small system with just a little bass to listen to now while I save up for the Big System
post #9 of 10 (permalink) Old 02-20-2013, 08:30 PM
iowaSSfan's Avatar
How do you like your Kicker 6X9s and 6.5s? I recently added two 10" Kicker Comps in the trunk and thinking bout 6.5 componets up front and maybe 4 6x9s in the rear deck, all Kicker.
iowaSSfan is offline
post #10 of 10 (permalink) Old 02-21-2013, 06:51 AM Thread Starter
I like them they were 100% better than the stock speakers that were in there (here are some vids to show where Im at now with my system)
