What to do?... - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 06-01-2013, 05:34 PM Thread Starter
Slayerdies's Avatar
Send a message via AIM to Slayerdies
What to do?...
Ok so I replaced all my stock speakers in the Impala with some Xplods I had laying in garage... well I also have this stuff laying in garage.
2 Infinity 12s in box and 1200watt xplod amp, a 600watt xplod amp, a really old 750watt Houston Acoustic amp. Also all the wireing to wire whatever I want up.
So... put the subs in and 1200watt xplod amp Yes.
What should I do with other two amps? Thought maybe use them to boost the xplod door speakers but all my amps are only 2 channel. Unsure if speakers in back deck can even handle the 600watt amp.
idk i just want the singing to match the bump ya know...
96 BBB Impala SS
Auto Climate, F-Body EGR, Gary's Batt Cables, Break Bolts, 160hyperstat, TB Bypass, Home Depot Intake/Hockey Puck and SwissCheeseAirBox, Try Y Gen II's, Pypes Xpipe,,Dynomax UltraFlows, Sprints, C3extend with solid uppers, NitroDrop2s, TruTrac with 3.73s
Work In progress... On a tight budget
Parts Sitting In The Garage...
S-10 converter, Blazer overhead
Slayerdies is offline
post #2 of 8 (permalink) Old 06-02-2013, 07:31 PM
Kilgore's Avatar
sell the other two amps and put the money towards the proper amp according to your speakers rms wattage
96 impala ss 48k
97 cbr-1100xx 22k
95 caprice 62k
Kilgore is offline
post #3 of 8 (permalink) Old 06-02-2013, 07:34 PM
Kilgore's Avatar
do you have an aftermarket stereo?
96 impala ss 48k
97 cbr-1100xx 22k
95 caprice 62k
Kilgore is offline
post #4 of 8 (permalink) Old 06-04-2013, 05:05 AM Thread Starter
Slayerdies's Avatar
I got a cheap aftermarket headunit.
I wouldnt be able to sell amps for much at all.
Rear xplod speakers say 240watt each with 50rms which aftermarket headunit puts out 50rms it says...
96 BBB Impala SS
post #5 of 8 (permalink) Old 06-04-2013, 09:16 PM
TGO
Assuming the 1200w amp was a 4 channel...I'd have used that for the door speakers and one of the 2 channel's bridged for the sub(s).
I mean ****, with a quality sub does it really make a difference? I remember running an adire audio shiva in my first car and I only had a 300-320 watt amp for that and it would pop up my sunroof without even trying.
TGO is offline
post #6 of 8 (permalink) Old 08-08-2013, 07:31 PM
Just use the extra amps. It wont hurt anything. If you use a 2ch. amp on the 4 speakers all you will lose is the ability to fade front to back.
souljasmooth is offline
post #7 of 8 (permalink) Old 08-08-2013, 08:22 PM
fuzzcar's Avatar
You could run the 750w amp to the front speakers and the 600 to the rears. But running those two amps plus the 1200 for the sub is going to create a whole lot of power draw which will likely mean you will have to add a second battery and/or upgrade alternator or add another alternator.
fuzzcar is offline
post #8 of 8 (permalink) Old 08-09-2013, 12:35 AM
coltonx3's Avatar
just use the 600 what amp and keep the amp down to almost nothing you'll be fine
95 9c1 dggm
straight black pvc kn filter
spintech pro street mufflers
most of trim and grill painted black
150k running strong and going
coltonx3 is offline
