I Have A Question - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 06-07-2013, 08:08 PM Thread Starter
Don.V's Avatar
I Have A Question
I Have two 12"s, 2 amps, Pioneer AVH-P5900DVD and what I believe is a power box supply with the right cables. My question is.... Is it normal for hearing the speakers pop when I turn the car off without turning off the deck first? I bought the car this way and I no chit about stereos.
Don.V is offline
post #2 of 8 (permalink) Old 06-07-2013, 08:46 PM
Kilgore's Avatar
hmmm. ive installed system in all my cars and have never had this problem. however, i had a system installed in my girls car professionally (because its new) and they "pop" when the car is turned off.
if you pull your head unit off, how many RCA cables are there hooked up? does the head unit have a set of RCA cables labeled "sub"? i ask because my subs get the signal from the head unit via RCA cables hooked up to the rear of the head unit to the amplifier, no pop.
head unit > rca cable > amp > subs
my girls car, on the other had, used "high level" input which is (i believe) you tap into the regular speaker wires, then hook that to the amp through the high level input, which then the amp takes the low frequency and runs them to the subs.
rear speakers > tapped wires "high level" > amp > subs
96 impala ss 48k
97 cbr-1100xx 22k
95 caprice 62k
Kilgore is offline
post #3 of 8 (permalink) Old 06-07-2013, 08:46 PM
Kilgore's Avatar
also what is this power box supply you speak of? is it a capacitor hooked up in the trunk near the sub box? or a power supply for the head unit hooked up near the dash?
96 impala ss 48k
97 cbr-1100xx 22k
95 caprice 62k
Kilgore is offline
post #4 of 8 (permalink) Old 06-10-2013, 02:19 PM Thread Starter
Don.V's Avatar
Right now I have my car garaged at my in-laws. At the end of the week I should pull out the deck and answer ur questions. Thanks for replying, I highly appreciate it.
Don.V is offline
post #5 of 8 (permalink) Old 08-08-2013, 07:29 PM
It can be normal. Some amps do this. If you have extra gear, swap a few things out and see if the pop goes away.
souljasmooth is offline
post #6 of 8 (permalink) Old 08-12-2013, 05:19 PM Thread Starter
Don.V's Avatar
What does gear mean? I know nothing about installing sound system. Thanx.
Don.V is offline
post #7 of 8 (permalink) Old 08-12-2013, 05:21 PM Thread Starter
Don.V's Avatar
Sorry for not responding, been hella busy with my kids and moving into a new house with a garage for the SS.
Don.V is offline
post #8 of 8 (permalink) Old 08-13-2013, 01:59 PM
Gear as in different products. Basically just swap out a different radio and see if the pop goes away...or amplifier. Sometimes its just a compatibility issue with certain products. Ive ran across this 100 different times.
