are the stock rear deck speakers supposed to be 8 ohm ? - Chevy Impala SS Forum
post #1 of 11 (permalink) Old 10-15-2013, 04:35 PM Thread Starter
Eracer's Avatar
They're both blown, which is why I am asking. thx in advance
EDit: And, umm, there don't seem to be that much of a selection of 8 ohm speakers. If I would want to upgrade to an amp/hu later, would it be feasible to buy some 4 ohm 6x9 and put a 4 ohm resistor in-line for now ?
The whole aim of practical politics is to keep the populace alarmed (and hence clamorous to be led to safety) by menacing it with an endless series of hobgoblins, all of them imaginary.
H. L. Mencken
Eracer is offline
post #2 of 11 (permalink) Old 10-16-2013, 01:16 PM Thread Starter
Eracer's Avatar
Noone knows ? harumph !
H. L. Mencken
Eracer is offline
post #3 of 11 (permalink) Old 10-16-2013, 01:25 PM
Mr pogo's Avatar
from what I remember, they should be stenciled on the magnets what ohms.
Mr pogo is offline
post #4 of 11 (permalink) Old 10-16-2013, 01:43 PM
coltonx3's Avatar
i thought 6x9 are in the back of all caprice/impalas
95 9c1 dggm
straight black pvc kn filter
spintech pro street mufflers
most of trim and grill painted black
150k running strong and going
coltonx3 is offline
post #5 of 11 (permalink) Old 10-16-2013, 04:08 PM
I'm not an audiophile but I believe home stereo system speakers are generally 8ohm, while most car systems are 4ohm.
post #6 of 11 (permalink) Old 10-16-2013, 07:01 PM Thread Starter
Eracer's Avatar
my bad; civi Caprice Classic, premium sound with cassette player lol.
They have 8ohms printed on em. Can't find 8ohm 6x9's. 90% of car audio is 4ohm.
So... 4ohm resistor in series ?
H. L. Mencken
Eracer is offline
post #7 of 11 (permalink) Old 10-16-2013, 07:49 PM
Send a message via AIM to 32assasin
amplifier provides a voltage and current to your speakers.
4 ohm driver allows more current to flow through it. this draws more power out of your amplifier and flows more power through the speaker
if you have an 8ohm amp (more expensive) then you can run two speakers in series without loosing any power.
if you have a 4 ohm amp, then what is the point to having 8 ohm speakers.
95 BBB 1 of 18,649 made
32assasin is offline
post #8 of 11 (permalink) Old 10-16-2013, 11:58 PM
you can replace the stock 8 ohm speakers with 4 ohm speakers. It will not negatively affect the stock radio (which can handle impedances from 4-10 ohms)
1986 fleetwood brougham 66k original miles. chevy 350/ BTO 200r4 swap. pypes dual exhaust. bravada buckets and console. buick turbines next up: lower it!
1983 buick lesabre "the pimpmobile" 68k bone stock
2000 GMC safari explorer high top conversion van. 192k on body, 179k on 1997 4.3 "Z" motor
previous vehicles
1987 chevy silverado "the beast" 115k motor donor.
1991 olds cutlass cruiser wagon. 180k. 3300 with high flow injectors
cadillac kevin is offline
post #9 of 11 (permalink) Old 10-17-2013, 01:51 AM
coltonx3's Avatar
ya just thow some 6x9 and call it a day my 9c1 has all after market speakers no amp and it sound good
95 9c1 dggm
coltonx3 is offline
post #10 of 11 (permalink) Old 10-17-2013, 06:05 AM
My new Rear Speakers from Infinity, which sound incredible BTW, are listed as.....
True Four Ohm Impedance technology: speaker's 2-ohm impedance combines with speaker wire impedance for a 4-ohm load
.....I dunno what all that means, but they sure sound much better than the old Kenwoods I had and the BASS difference is huge.
http://www.crutchfield.com/S-7vGLRDy...ce-9633cf.html
