Amp locations? - Chevy Impala SS Forum
post #1 of 17 (permalink) Old 11-04-2013, 11:02 AM Thread Starter
kjearl's Avatar
Amp locations?
Where are you guys mounting your amps? I am planing to add two or three amps to a RMS.
I am not sure where I should mount them; I want them to be out of the way and mostly unseen. Was thinking up behind the spare but there isn't a whole lot of room up there.
kjearl is offline
post #2 of 17 (permalink) Old 11-04-2013, 04:57 PM
Here is mine on the Impala. An Impala SS wheel with a stock size tire I use for a spare does fit when I do carry one.
96 Buick Roadmaster Limited Wagon-Divorce SUCKS! http://www.streetfire.net/video/96-buick-roadmaster-wagon-burnout_177522.htm
96 Chevrolet Impala SS LE2 H/C with other supporting mods SSHS12 Heavy Eliminator Winner
90 Toyota Tercel Rallye
79 Chevy Nova 406ci SuperRam EFI setup [email protected] FOR SALE
If NISMO stands for Nissan Motorsports...does HOMO stand for Honda Motorsports?"
BlowNdoh is offline
post #3 of 17 (permalink) Old 11-04-2013, 11:25 PM
RobSS's Avatar
Build a simple amp rack and bolted through floor
RobSS is offline
post #4 of 17 (permalink) Old 11-05-2013, 07:25 PM Thread Starter
kjearl's Avatar
That is what I was thinking of going with, looks good. Did you just screw it into the back of the seat? Do you have a picture with the spare in place?
kjearl is offline
post #5 of 17 (permalink) Old 11-05-2013, 08:06 PM
I don't have a pic with the stock size tire. I have ET streets on the spare wheels now. If you want I can take a pic with my ET street on stock Impala wheel in the same spot for you.
They are just screwed into the metal "bracing" not actually the seats but you probably meant the bracing anyways.
BlowNdoh is offline
post #6 of 17 (permalink) Old 11-06-2013, 10:17 AM Thread Starter
kjearl's Avatar
If its not too much trouble I would like to see what that looks like. I am trying to do as little drilling into anywhere on the car as I can.
I might make some kinda rack out of wood and have the spare tire hold it in place.
kjearl is offline
post #7 of 17 (permalink) Old 11-06-2013, 12:18 PM
RobSS's Avatar
If u want clean and simple I would take a piece of mdf the size of that rear seat area and cover it in some carpet to match the trunk. Attach that to the rear seat bracing then mount your amps to it. I used to have it like that but I don't have any pics
RobSS is offline
post #8 of 17 (permalink) Old 11-06-2013, 01:02 PM Thread Starter
kjearl's Avatar
I think thats exactly what ill do thanks.
kjearl is offline
post #9 of 17 (permalink) Old 11-06-2013, 03:39 PM
juniorwatson's Avatar
Since I currently have on the OEM 9C1 wheels, and have a spare in the trunk, I installed mine to the bottom of the package tray.
I also used socket head fasteners, and Ny-Lock nuts to prevent theft.
juniorwatson is offline
post #10 of 17 (permalink) Old 11-06-2013, 04:07 PM Thread Starter
kjearl's Avatar
Wouldn't that get in the way of the speakers?
kjearl is offline
