GM CD Changer - Chevy Impala SS Forum
post #1 of 1 (permalink) Old 03-15-2014, 09:17 AM Thread Starter
GM CD Changer
Hello I have a 1994 RML. I changed the dash bezel to a 1995. I now have a 1999 Aurora CD/Cassette head unit in it. It is similar to a Monsoon unit. (I also have a 1999 Aurora with an added Delco 12 CD Changer using existing harness).
I have spliced in the Aurora plug into the car's harness. (the plug is the same as a 1995-1996 RML plug).
The unit works perfectly the only thing is I could not adapt the dimmer wire that goes to the Climate Control unit, so its lights are always full on bright.
So I once found a harness that adapts a CD changer to the head unit, it fit perfectly but had a short. I returned it and all this supplier's harnesses turned out to have a short (they were Delco harnesses, but apparently defective). They had a "T" configuration where you would plug one end into the unit the other into the car's main harness and then the harness goes to the CD changer from there.
I also have sitting around a Corvette CD changer harness, but nowhere to plug it in on the head end. I guess it would plug into a place in the Corvette's main harness.
So, does ANYONE know how I can get my CD changer wired into my head unit that would normally accept a changer if the wiring were done properly?
59186 is offline
