0 gauge to 8 gauge? - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 07-07-2014, 01:40 PM Thread Starter
boofers's Avatar
0 gauge to 8 gauge?
Noob audio question, would there be a problem to go from 0 gauge to 8 gauge in a dist block? My old fosgate amps only take 8 gauge and i think the terminals are to close together to use a reducer.. thanks
1996 BBB, 396ci Golen LT4, Yank 3600, TransGo shift kit, 3.73s, P71 MMC driveshaft, CIA Tri-Y Gen II, X-Pipe, Dynomax UltraFlo exhaust, Hotchkis Sway bars & Springs, Bilstein Shocks, UMI extended control arms, ODBI conversion, all installed and tuned by Mike Harris
boofers is offline
post #2 of 2 (permalink) Old 07-07-2014, 04:37 PM
No, although you'll be limited to the current carrying capability of the 8 gauge. If you try to draw more and don't have it fused to an amperage below the 8 gauge capacity, that section of wire will act as a fusible link. That said, since your amplifier is designed to only use 8 gauge, you're not likely to run into an over-current situation.
Another thing to consider is if your distribution block is capable of accepting an 8 gauge size wire. It may not be designed to accept something that small if it has a 0 gauge input.
threeimpalas is offline
