Removal of rear speaker covers - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 06-06-2003, 03:44 PM
4DRVET
Red face
It's a pretty basic question, but I've never had to remove them before. They are attached pretty good and I don't want to damage the connects. Thanks in advance....
post #2 of 6 (permalink) Old 06-06-2003, 03:54 PM
Mags94
The have four clips thingys that hold them to the rear deck. Best way to remove them is to go into the truck and you'll see them. Using some pliars you can get them out, just take you time doing so because they are crapy just like everything else in these dam cars.
post #3 of 6 (permalink) Old 06-06-2003, 03:55 PM
96SSIMP
Just get your hands under them and pull each corner out. You can also access the clips from inside the trunk but you might have to jump in the trunk for that. They should pull right out with some force.
post #4 of 6 (permalink) Old 06-06-2003, 04:20 PM
mrthump77
I used the 4 corner pull method. Only thing is sometime the clips stay in the holes and not on the grills. 96SS is right about having to get in the trunk for that one. Might want to get in there w some pliers to close the little "grabber" on them so you can push them out.
post #5 of 6 (permalink) Old 06-06-2003, 06:19 PM
4DRVET
Talking
Thanks for the quick response guys, I appreciate it.
post #6 of 6 (permalink) Old 06-06-2003, 09:42 PM
college slacker
Or you could just take out the whole rear deck, right?
