WHATS THE PROBLEM!!!?!!!! - Chevy Impala SS Forum
post #1 of 9 (permalink) Old 04-25-2007, 08:55 AM
TurboLT1
Ok my set up is:
2 Cerwin Vega Stroker 12's and 1 5000w BOSS Blade. I only have one sub hooked up to the amp currently and it sounds horrible. All three items were brought brand new. The amp i cot off ebay listed as NIB not refurbished, and it arrived that way. What do i need to do to get these things to knock like they are supposed to?
post #2 of 9 (permalink) Old 04-25-2007, 09:50 AM
the96pala
I'm assuming you have the + to + and - to -?
post #3 of 9 (permalink) Old 04-25-2007, 10:22 AM
therealist
what type of enclosure and specs on it
post #4 of 9 (permalink) Old 04-25-2007, 10:27 AM
TurboLT1
correct positive is to positive and negative is to negative.... the enclosure is just a wood box that had the depth that speaker manufacturer suggested. When i first hooked it up they, well i have only hooked one up at a time, they would hit but after blowing a couple fuses they don't do anything.
post #5 of 9 (permalink) Old 04-25-2007, 04:05 PM
UndercoverPunk
You're blowing fuses? Main power fuses or on the amp it's self? How ungodly high is your gain?
post #6 of 9 (permalink) Old 04-25-2007, 05:06 PM
TurboLT1
Originally posted by UndercoverPunk:
You're blowing fuses? Main power fuses or on the amp it's self? How ungodly high is your gain? [img]graemlins/.gif[/img]
Main power fuses... Only think i've done with gain is turn it down.
post #7 of 9 (permalink) Old 04-25-2007, 05:47 PM
therealist
Is your box ported or sealed and did someone make it or prefab?What size fuse are you using on your main power wire?
post #8 of 9 (permalink) Old 04-25-2007, 06:18 PM
PIMPALA-SS
take it to a professional
/end thread
post #9 of 9 (permalink) Old 04-25-2007, 06:29 PM
TurboLT1
120 ANL fuse, ported prefab box.
