Where in the firewall can I run a power wire? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 07-25-2002, 05:56 PM
Klez
I am going to install my Bazooka tube tonight and wanted to know where is the best place to run the power wire through the firewall. I took a quick look last night but I did not see the usual empty hole with the rubber grommet/cap in it.
Thanks
for any info
post #2 of 4 (permalink) Old 07-25-2002, 07:05 PM
Southern Comfort
If you pull back the carpet on the passenger side you will see a hole in the firewall leading to the engine compartment.
post #3 of 4 (permalink) Old 07-25-2002, 07:59 PM
toomanytoyz
On the driver's side there should be a 2" (or so) rubber grommet with wires coming out of it on the firewall under the steering shaft. In that general area anyways. Ya can't miss it. [img]smile.gif[/img]
Good luck.
post #4 of 4 (permalink) Old 07-25-2002, 08:27 PM
Klez
Thanks I got it in there!
