Front Door Speaker boards - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 04-18-2002, 12:56 PM
ShowSS12
I have 3/4 inch MDF that I would like to cut to fit some 6 1/2 componets in the front doors, But the plans read that it needs to be 1/2 plywood or particale board.
But would 3/4 MDF pose a problem with anything if i use it?
TIA
post #2 of 4 (permalink) Old 04-18-2002, 06:14 PM
HACK
1/2 is the minimum that I would use, 3/4 should be fine.
post #3 of 4 (permalink) Old 04-18-2002, 07:26 PM
camel
i used 3/4 i found i had to cut a little off the template. and had to sand down some areas to allow the door panel to be flat. but can be done. 1/2 would be best.
post #4 of 4 (permalink) Old 04-20-2002, 07:46 AM
Hey Boom
Cool
3/4 inch is fine. That's what several folks have used and like Camel said, you'll just need to sand / shave some off the edges. If you need some help, I'm up in the Bear Creek area off 6 & Clay.
