System shuts of and turns back on - Chevy Impala SS Forum
post #1 of 15 (permalink) Old 03-13-2007, 12:10 PM
Caddylack
For the past 2 days, my stereo (HU, speaks, amps, subs, everything) has been powering off randomly and then immediately powering on again. It happens at both high and low volumes and sometimes it happens every few hours, while sometimes it happens every couple minutes. I checked all my connections and everything appears fine. What could be the issue?
post #2 of 15 (permalink) Old 03-13-2007, 01:00 PM
UndercoverPunk
Sounds like head unit wiring to me.
The head unit shuts down the amps are going to shut down because the no longer get the 12V remote signal.
Pull the headunit and make sure everythings fine.
post #3 of 15 (permalink) Old 03-13-2007, 02:31 PM
the96pala
Tough to say. Could be a loose wire somewhere, could be a voltage issue where you are getting spikes in the voltage or could be just a bad HU.
How old is the HU? Have you done anything to upgrade the power?
post #4 of 15 (permalink) Old 03-16-2007, 04:36 PM
gvillepoet
mine was doing that til i went behind the dash and pushed on the wires going INTO the wiring harness of the head unit....
i guess it was the moves from hydraulics...but anyways it works now.
post #5 of 15 (permalink) Old 03-19-2007, 08:27 AM
Mr.Dark-Saint
That reminds me of a bad ground I once had. But loose connection sounds like a culprit. I feel for you since you have to go arm deep in that octopus and all the possible connection junction.
post #6 of 15 (permalink) Old 06-06-2007, 08:35 PM
texasboyy02
man im having the same problem kind of sort of--except my head unit stays on but no sounds comes out my speakers... i have an amp powering my speakers--but everything is connected fine--the fuses look fine also--im stuck
can a fuse be bad even though it doesnt look blown?
post #7 of 15 (permalink) Old 06-06-2007, 08:49 PM
UndercoverPunk
You're sure the amp isn't blown?
post #8 of 15 (permalink) Old 06-07-2007, 09:21 PM
texasboyy02
if it isnt--its going out... cuz it comes on and off...so i dont think its wiring or the fuses
post #9 of 15 (permalink) Old 06-08-2007, 02:38 AM
soul
Does the amp get hot?
post #10 of 15 (permalink) Old 06-08-2007, 01:17 PM
UndercoverPunk
Loose connections? Ground maybe.
