92 Caprice Stereo questions... - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 10-05-2006, 02:39 PM
PunisherSS
I need to replace front speakers and Stock Head unit on my 92 Caprice wagon...What size is the stock Front speakers and 96 impala stock stereo will fit directly to my car ??
post #2 of 4 (permalink) Old 10-10-2006, 06:56 AM
savagebee
I dont think the impala stereo will bolt in, but I bet you could make it to work...
the front speakers are (I belive) 4x6's... you could make a baffle out of mdf pretty easily and change it up though (im running 6.5" components now)
post #3 of 4 (permalink) Old 10-11-2006, 11:59 AM
ferrstein
I put a '96 CD player in my '92. The wiring will plug right in, but mounting it is tricky. I basically adapted the plastic bracket from the '92 radio to fit onto the '96 radio. I think I had to remove the lid from the '96 radio and put a bolt through it to the plastic bracket. It should be fairly intuitive once you're looking at both radios. Some trimming of the '92 bracket was required.
post #4 of 4 (permalink) Old 10-11-2006, 03:27 PM
PunisherSS
my concern was wiring...I can work on the brackets no problem ..
Thanks for helping...
