amp - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 06-22-2002, 02:27 PM
tony102385
Do your subs and speakers use the same amp or do you need different amps?
post #2 of 6 (permalink) Old 06-22-2002, 07:07 PM
dxception
You really should use two for maximum benefit. I have one 300W for my sub and a 4way amp for my speakers. That is, unless you get a very expensive amp. You also wouldn't want to over work one amp.
post #3 of 6 (permalink) Old 06-23-2002, 05:28 PM
tony102385
I have a 1000 watt amp should that be fine for the speakers and one 10 in sub
post #4 of 6 (permalink) Old 06-24-2002, 06:33 PM
corvette61
Tony, that amp will probably be too strong for the smaller high frequency speakers, and would even need a pretty healthy sub to handle the power. I'd recommend a 5 channel amp with appx 30-50 watts times four and between 100-300 watts times one for the sub. Most manufacturers of car audio gear have one in the line-up we do Alpine, Rockford, Clarion, MTX and Eclipse and they all offer something anywhere from 300-800 dollars. If you are wanting to use that amp, I'd say to get a four channel amp with somewhere around 75-100 watts times four to match your 1000w amp in volume. You'd need really high quality component speakers to handle that much power though.
post #5 of 6 (permalink) Old 06-24-2002, 08:17 PM
tony102385
I have a kenwood 1000 watt amp but thats the peak power its 2 channel so could i hook that to the rear speakers and sub and leave the front speakers alone. My rear speakers can handle 220 watts of power.
post #6 of 6 (permalink) Old 06-24-2002, 10:08 PM
candy SS
u will need to run the sub on low pass and the rear speakers on high pass. if u run them on the same 2 channel amp the sub will play notes too high or the rear speakers will play notes too low. u can get away with a 4 channel amp if u run the rear speakers on the front out puts on high pass, and the sub(s) on the rear outputs on low pass.
good luck.
