14.4 Volts ??? - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 09-06-2003, 05:39 PM
Mike Lowry
Alpine gives ratings for their amps running at 14.4 volts... When does a car put out that much volatge? I thought it was 12V ? Does anybody know how to make the alternator put out 14.4 volts?
Mike
post #2 of 10 (permalink) Old 09-06-2003, 05:41 PM
threeimpalas
Your alternator puts out ~14.4 volts when the engine is running.
post #3 of 10 (permalink) Old 09-06-2003, 05:41 PM
mtxpert
You can't charge a 12V battery with a 12V alternator....
You'll see voltages between 12 and 15 V normally during charging/maintaining of the battery.
Mike
post #4 of 10 (permalink) Old 09-06-2003, 05:47 PM
mtxpert
More info:
Google Groups
Mike
post #5 of 10 (permalink) Old 09-06-2003, 06:43 PM
Mike Lowry
Thumbs up
I see.. you know I could never understand why Alpine always advertised that 14.4 volt ratings.. thanks guys... now what's the deal with a 14V battery...anybody ever used one?
Mike
post #6 of 10 (permalink) Old 09-06-2003, 10:22 PM
threeimpalas
You shouldn't use a 14 volt battery in a car designed for a 12 volt. While it should work relatively fine, the wiring and alternator isn't designed to handle the increased voltage required for operation.
post #7 of 10 (permalink) Old 09-06-2003, 11:54 PM
GODSPEED
need juice.
post #8 of 10 (permalink) Old 09-07-2003, 02:52 AM
redimpss
you mean like a gin and juice??????
post #9 of 10 (permalink) Old 09-07-2003, 03:27 AM
Mike Lowry
"Cuz my minds on my money and my moneys on my mind"
Well is it better to get a second battery or a capacitor? I heard Stinger makes really good electrical equipment...
post #10 of 10 (permalink) Old 09-07-2003, 09:56 AM
threeimpalas
A second battery wouldn't help while the car is running. It would let you run the stereo for a longer time while the car is off however. A capacitor may or may not be needed depending upon how much power your amps draw on hard hitting bass notes.
