SCV on a 94 - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 11-01-2003, 08:48 PM
Raxstone
I have used the search, but all the available links have as of yet not been answered. I have a 97 theft-loc delco with scv installed in my 94 caprice. What do I need to wire into in order to get the scv to work? Since the original harness did not have scv, and I know there is an empty slot or two in the harness, I imagine that I need to add a wire to the harness, and run it to ... perhaps the speedometer? The wiring diagram I looked up at install doc did not have the scv, but also shows the empty slots in the harness. My impression is that this diagram is therefore out-dated.
post #2 of 7 (permalink) Old 12-31-2003, 08:34 AM
Raxstone
Bringing this back to the top, since no one has yet responded. Hasn't anyone had to toss in their own SCV wiring?
post #3 of 7 (permalink) Old 12-31-2003, 01:59 PM
bbodyguy
When I installed an overhead console in my 94, I picked up the vss in the big connector that has about 30 - 40 wires in a square underneath/by the steering column. I dont have my fsm handy right now, but it was near the center of the plug. You dissconnect the plug w/ a 7mm socket to get better access to the wire. You need a FSM to pick off the right wire by refrence to the connector face.
Peter
post #4 of 7 (permalink) Old 12-31-2003, 07:36 PM
Vss to pin 16 on the back of the radio.
post #5 of 7 (permalink) Old 01-02-2004, 06:37 PM
Raxstone
What is VSS? Is there a manual that covers wiring I should pick up?
post #6 of 7 (permalink) Old 01-02-2004, 06:44 PM
96capriceMGR
Vehicle Speed Sensor
A Factory Service Manual would be the best source for wiring info cost around $100. I have looked through a friends and if you are going to do much with the car it is worth the money.
post #7 of 7 (permalink) Old 01-03-2004, 10:59 PM
rablair
Do any of the '94-'96 cars have the VSS run to the radio connection?
I have a late model Delco CD radio with SCV in my '95 but I can't really tell that it does anything.
I second that about the Factory Service Manual. They can't be beat. There is someone selling them on eBay for about $60.
