good ground spot for amp? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 01-25-2004, 12:36 AM
claSSic Caprice
I can't find any good grounding location for my amp in my trunk, the spot im using now(trunk support thing) has all of a sudden started to give me problems like cutting of power to my amp unless I tap the ground wire.
post #2 of 4 (permalink) Old 01-25-2004, 01:56 AM
azroadmonster
How well did you prep the grounding surface, and how tightly is the gound crimped/secured?
post #3 of 4 (permalink) Old 01-28-2004, 04:29 PM
Mitchell
Bare Metal, Star washer, Tight bolt?
post #4 of 4 (permalink) Old 01-28-2004, 07:28 PM
college slacker
Use the back seat bolt to ground your system. I use it and have had zero problems. Of course you should remove the paint and grease in the area first
