CB Question - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 06-03-2003, 05:14 PM
MrMaJ
Arrow
I was wondering if anyone could help me with a CB issue I am having. The CB works ok in the car but not when the car is running. When I turn it on the level meter hits the top and it's all white noise from there. Also, when I rev the car up you can hear the whine get louder as the car idles faster. This CB works fine in every other car I have had it in. It also works ok in a 9C1 that my brother had. I am running it in a 96 SS. It is connected through the Cig lighter for power. I don't believe the car has resistor plugs. Are there any measures that I should take to make the noise go away that is caused by the car being on?
Thanks in advance, MrMaJ
post #2 of 3 (permalink) Old 06-03-2003, 07:02 PM
bbodyguy
Just for giggles I would run a seperate ground to the unit.
Peter
post #3 of 3 (permalink) Old 06-05-2003, 02:14 PM
MrMaJ
Arrow
Thanks for the advice. I will have to try that. Anyone else have any suggestions?
