running amp wire - Chevy Impala SS Forum
post #1 of 6 (permalink) Old 11-07-2006, 07:10 PM
94fleet
What the best way to run an amp wire from the battery to the trunk?
post #2 of 6 (permalink) Old 11-07-2006, 07:36 PM
cressida1992
hey,run it up tha fender down behind the fuse block and find where the ant cable goes through the body pull tha gromet and fish it through there down in the kick panel,pull the kick panel and door sill lift tha carpet to access tha factory harnes holder pop that open and run tha amp cable all tha way through to tha rear along side the back seat find a hole somewhere beside the top of the back seat or anywhere in between and its a done deal.plans may diffrent on tha fleetwood because i have a 96ss and thats how i did it,hope it helps you though,let me know how it works out.holla
post #3 of 6 (permalink) Old 11-07-2006, 07:53 PM
cuba069
Everything he siad but be sure not to cross the wire, with any other wires do the same with the ground....and then add the boom
post #4 of 6 (permalink) Old 11-07-2006, 08:44 PM
NINE FOUR 9C1
too bad u dont have a 9c1 theres all sorts of holes in the firewall to run it through
post #5 of 6 (permalink) Old 11-08-2006, 07:43 AM
FOURDRVET
what guage
post #6 of 6 (permalink) Old 11-12-2006, 10:36 PM
UndercoverPunk
I just ran plastic flex conduit under the car.
<---cheater.
