stock radio replacement - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 07-27-2002, 12:15 PM
sh0cknock
Does anybody have a solution to replace the stock radio in my 95 SS with soming much nicer. The depth is so little that it seems like a losing battle.
post #2 of 8 (permalink) Old 07-27-2002, 06:10 PM
SSpecial
Thumbs up
go to www.caraudioexpert.com they have some nice radios
post #3 of 8 (permalink) Old 07-27-2002, 11:04 PM
medicalss143
best fit in d place of stock headunit is:
Pioneer DEH-P77DH
CD Player Specifications
Anti Theft: Removable Faceplate
Preamp Outputs: 3 sets
Preamp Output Voltage: 4 volts
CD Changer Controls: Yes
Remote Control: Yes
RMS Power: 22W x 4
Peak Power: 45W x 4
CD Frequency Response: 5-20,000 Hz
FM Mono Sensitivity: 10 dBf
CD Signal-to-Noise Ratio: 94 dB
Amp Total Harmonic Distortion: n/a
Shipping Weight: 6.5 lbs
Warranty: 1 year
try this --> Car Audio Domain
post #4 of 8 (permalink) Old 07-27-2002, 11:39 PM
sh0cknock
hi, and thank you for the ideas. Do you have this Pioneer mounted in your car? Crutchfield seems to think this unit will not fit the 95 Impala SS.
This unit would make my day.
Do you have a picture of it in the car?
thxx much
post #5 of 8 (permalink) Old 07-31-2002, 02:40 PM
impala-joe
Other then taking off the dash installing the Pioneer was the easiest install I have ever done. I got mine from; www.broadwaycomputer.com
they had the best in-stock price with shipping I could find. *note* the -P77DH model is no longer made and can be hard to find the -P45DH model is every ware. I also ordered a factory wire harness form them. The only problem I have noticed is the the dash light dim switch does not work with the head unit, I have not pulled the dash back off to find out what the problem is. I have a photo of it installed I am not sure how to post it here, so I will e-mail it to you if you want.
post #6 of 8 (permalink) Old 08-01-2002, 08:15 AM
aggie ss
Impala-Joe, I just installed mine last weekend. There is a setting in the radio itself to turn 'ON' the dash dim light function. It is 'OFF' by default.
I'm still learning all the functions this unit can do myself. If you want to see pictures, go here: Radio/Carpet Install Pictures
Use the 2 smallest mounting brackets and one bolt-post supplied in the back and it fits like a glove.
post #7 of 8 (permalink) Old 08-01-2002, 10:03 AM
LT1SS96
I'm not sure of the model #'s but Alpine has a unit or two that will fit the entire space like the Pioneer unit does.
post #8 of 8 (permalink) Old 08-02-2002, 06:46 AM
LATimeSS
Go with the alpine decks. They have some 1.5" din decks that fit great in GM cars. I put one in my 95 SS. I believe the model number is CDA-853. I love it. It's between $500 and $600 retail but I got mine on Ebay for $260 new. Install was no sweat and they look a lot nicer than the Pioneer decks. If you need anymore info just hit me up.
