little help guys - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 05-15-2002, 05:39 PM
LUCKY931
i decided to cut out the rear deck to port let the bass in from the trunk...i just purchased infinity kappa 6.5 components for the front and infinty kappa 6x9 for the rear.., heres my question. I have a four channel amp now, one channel to each speaker. can i bridge it two a two channel configuration i.e. one channel to the rear and the other to the front or left to right? I know i can bridge the amp but what can i expect from this other than more power? pros? cons? any help would be greatly appreciated as always.
post #2 of 2 (permalink) Old 05-15-2002, 06:00 PM
camel
it would be the same power to each speaker. you might get double when you bridge it. but then when you figure that you have to wire your speakers in parallel it would be the same. i would leave it how it is, i don't think you would benefit anything from bridging it. i think al that you would do would be messing up your right and left signal, you would be in mono instead of stereo.
