could anybody, POSSIBLY know how or have a Diagram for this wiring? - Chevy Impala SS Forum
post #1 of 13 (permalink) Old 10-07-2002, 06:59 PM
4doorSS
I just built my entire new trunk setup, Too-bad its still uncarpeted,and sorry no pics yet you'll like em when I post them I'm sure [img]smile.gif[/img] I still need to tweak some wiring.. So, thats what i need to know:
does anybody know how to wire 3 subs @ 4ohms into one set of speakerwires. (1 + 1-) so I can bridge it to my amp.
It Was done right when i got them in the box, but then i took the subs out, and built all seperate boxes, and they arent all next to each other.
anybody have a diagram or can make a quick one for 3 subs and "just say" one "box connector"..
-thanks you stereo Freaks!!
post #2 of 13 (permalink) Old 10-07-2002, 07:16 PM
Vador
What subs you got (i.e. 2-ohm/4-ohm, dual voice coils)? What amp?
post #3 of 13 (permalink) Old 10-08-2002, 05:41 AM
gbelli
http://www.cbrstereo.com/dual_voice_...g_tutorial.htm
I dont remember if they are 4ohm voice coils though.
I remember that when I did wire them up, it was fun. I might still have the wiring sheet I was sent at my parents house back in the burg. I'll be out there tomorrow or the day after.
post #4 of 13 (permalink) Old 10-08-2002, 08:30 AM
jelzey
3 speakers at 4ohms a peice gives you 1.333 ohms in series. (1/[(1/4)+(1/4)+(1/4)]) You need another sub to get 1 ohm. Or get rid of one sub and you get 2ohms. If they are dual voice then that will be a different story.
post #5 of 13 (permalink) Old 10-08-2002, 08:41 AM
gbelli
The subs, when I bought them and wired them it represented a 4ohm load to the amp according to the wiring sheet.
Yes, they are DVC [img]smile.gif[/img]
post #6 of 13 (permalink) Old 10-08-2002, 09:53 AM
z_bassman
<BLOCKQUOTE>quote:</font><HR>Originally posted by TWiG:
3 speakers at 4ohms a peice gives you 1.333 ohms in series. (1/[(1/4)+(1/4)+(1/4)]) You need another sub to get 1 ohm. Or get rid of one sub and you get 2ohms. If they are dual voice then that will be a different story.<HR></BLOCKQUOTE>
Three 4-ohm speakers in parallel give you a 1.3 load. Put them in series and you have a 12-ohm load. Two in series with each other and in parallel with a third would be what, 6 ohms?
post #7 of 13 (permalink) Old 10-08-2002, 10:20 AM
MOORESS
don't forget guy's that If you bridge you amp it will only see half of the impedance for instance if you parallel 2 8ohm woofer's you would get 4 ohms of resistance put that to the amp bridged and the amp would see 2 ohms so Zbassman has the best route
<BLOCKQUOTE>quote:</font><HR> Three 4-ohm speakers in parallel give you a 1.3 load. Put them in series and you have a 12-ohm load. Two in series with each other and in parallel with a third would be what, 6 ohms?
<HR></BLOCKQUOTE>
The final that the amp would see would be 3ohms IF your amp is only rated at 2ohms bridged this is your safest bet
later
Donnie
post #8 of 13 (permalink) Old 10-08-2002, 11:19 AM
jelzey
Sorry, i meant parallel and 2 in series and 1 in parallel give 2.66 Ohms not 6. A good way to figure a rough estimate is that the final ohms will always be lower then the smallest ohm load when involving parallel (so 8 & 4 thus less then 4).
post #9 of 13 (permalink) Old 10-08-2002, 11:40 AM
jelzey
The only 3 speaker setup I know of are the JL 6 ohm series. You still need to get rid of or add a speaker. Most amps do not like the strange ohm loads and can run hot.
post #10 of 13 (permalink) Old 10-08-2002, 04:20 PM
4doorSS
Yes they are 4ohm Dual Voice coils (old fosgate 10"s) with a kenwood 600W amp. ( i know, not the greatest for sound quality )
LOL greg, i took the subs out, to measure the box for Cu-area, and to measure the depth for the box, and So i totaly got confused with the wires in the box so i kinda confused myself pretty bad... [img]3.gif[/img]
you guys REALLY have me confused, so your saying go 2 ohm even though there 4ohm subs?
I wish i never undid the wiring, it sounded badass before,
