Best place to mount crossover? - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 07-23-2003, 06:06 AM
college slacker
FOr anyone who has components in the front doors, where did you find it easiest to install the crossover? I can't remember seeing any pics of anyone's mounting locations.
Also, when putting in Brown Bread (or Dynamat if you prefer that brand), did y'all completely remove the plastic water guard sheet in the door and not put it back in? Just making sure before this weekend. Thanks [img]smile.gif[/img]
post #2 of 8 (permalink) Old 07-23-2003, 07:20 AM
bbodyguy
I put them in the dash, and ran four conductor trailer wire thru to the door. The wire is available at Pep Boys and is 16 gauge.
Peter
post #3 of 8 (permalink) Old 07-23-2003, 08:25 AM
catdaddy
I installed the crossover box in the pockets of the door panels. I took the plastic off the doors before I installed dynamat. (plastic will keep dyna from sticking on the door)
post #4 of 8 (permalink) Old 07-23-2003, 09:40 AM
SSWEETDGGMSS
If you take a look on my website listed below, look at the "Front Fill" section. It shows how I mounted them in my door.
TOM B
post #5 of 8 (permalink) Old 07-25-2003, 06:09 AM
college slacker
Talking
THanks for the info, guys. I'm sure I'll see y'alls' options better when i take the door apart this weekend.
Now, instead of making another topic i have another question. Is there a real need to put the speaker grills on the speakers under the door panel's grill? Thanks again [img].gif[/img]
post #6 of 8 (permalink) Old 07-25-2003, 06:36 AM
toomanytoyz
<BLOCKQUOTE>quote:</font><HR>Originally posted by X college slacker:
Now, instead of making another topic i have another question. Is there a real need to put the speaker grills on the speakers under the door panel's grill? Thanks again [img].gif[/img]<HR></BLOCKQUOTE>
Nope. No need for it. [img]smile.gif[/img]
post #7 of 8 (permalink) Old 07-27-2003, 06:44 AM
college slacker
<BLOCKQUOTE>quote:</font><HR>Originally posted by catdaddy:
I took the plastic off the doors before I installed dynamat. (plastic will keep dyna from sticking on the door)<HR></BLOCKQUOTE>
Ok, now how did y'all keep the mechanical stuff behind it (locking mechanism, rods, etc...) from sticking to the dynamat? Man, am i a rookie at car audio, or what? [img].gif[/img]
post #8 of 8 (permalink) Old 07-27-2003, 06:05 PM
SS964mo
<BLOCKQUOTE>quote:</font><HR>Ok, now how did y'all keep the mechanical stuff behind it (locking mechanism, rods, etc...) from sticking to the dynamat? Man, am i a rookie at car audio, or what?<HR></BLOCKQUOTE>
If you must use it behind the rods, you will need to cut it in small pieces and stick a little at a time. If I remember right the largest piece I suck might have been 8X7.
I also removed the arm rest to make it easier and reinstalled them with stainless steel bolts.
Prep: clean the metal with laquer thinner first. A heat gun will make the dynamat stick better, heat the piece and stick it on then heat again and run a roller over it.
Have and don't burn your fingers or anything behind the metal
Here are some pictures of mine to get ideas.
I'll post these but there are a few more in that link.
