Questions on which set of speakers - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 10-21-2006, 10:28 PM
audi1031
Do you think that this sounds correct?
I am looking to run 4 kicker 15's and I have to get it so that the amp will see 1ohm with these. Would getting 4 - 8 ohm 15's? I am asking because person has 2 - 4 ohms and also 2 - 8 ohms and wanted to see which would go best since i would have to purchase 2 more. The amp that I will be using is a MA audio hk802sx 2 channel amp
1 x 4400 Watts RMS @ 1 Ohm Bridged
2 x 2200 Watts RMS @ 0.5 Ohm Stereo
thanks for input as i am waiting on response before buying the set up
My other option would to buy 2 4 ohm kickers L7 get a box made and call it a day
post #2 of 8 (permalink) Old 10-21-2006, 10:49 PM
poohizzle
if u want to create a 1ohm load u need the
2-4ohm woofers and two more and u would have to have parallel all of them. Meaning all positives and all negatives together. [img]tongue.gif[/img]
post #3 of 8 (permalink) Old 10-21-2006, 10:51 PM
poohizzle
assuming that they are Kicker Comps black and yellow right just asking.
post #4 of 8 (permalink) Old 10-22-2006, 12:07 AM
audi1031
so having all four 4 ohm speakers bridged that will be one ohm or to get the 4400 or so power correct?
post #5 of 8 (permalink) Old 10-22-2006, 06:57 AM
USAFCaprice
i cant agree w/ pooh'ss.. dual 2s are the way to go.. see diagrams- dual 2 ohm or dual 4 ohm
post #6 of 8 (permalink) Old 10-22-2006, 07:13 AM
HACK
If you do 4 4ohm speakers single voice coil, it will be 1 ohm.
If you do 4 4ohm speakers dual voice coil, it will be .5 ohm.
There is no difference in sound quality from a single to a dual voice coil. It is just a way to configure the speakers to get the correct ohm load on the amp.
post #7 of 8 (permalink) Old 10-23-2006, 09:36 AM
poohizzle
THANKS HACK , oh and JBONE HACK is also right it dosent matter how many voice coils or load they are cause having a DUAL 2OHM is the same as having a SINGLE 4OHM SPEAKER UNLESSSS u want a 1OHM load on a single speaker.......
post #8 of 8 (permalink) Old 10-23-2006, 09:52 AM
audi1031
Yea thanks I just picked up 2 more SVC 4 ohms which 4- 4ohm SVC 15's
