Radio removal 2004 Impala - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 11-02-2006, 05:22 PM
jevz1
Can anyone direct me to instructions on-line to remove the radio from my 2004 Impala. I want to replace the OEM am/fm/cassette with an OEM am/fm/cassette/CD.
Also, will these radios need a code entered after installation?
Thanks.
post #2 of 12 (permalink) Old 11-02-2006, 09:40 PM
MrCadillac
Sure thing... Find a Wimpala forum. This is for the 1994-1996 Impala, ya know, the REAL Wheel driven one.
Goodluck finding somebody on here with the info you want... Bet somebody knows, but will they find this? or take the time to tell?
post #3 of 12 (permalink) Old 11-02-2006, 10:25 PM
PIMPALA-SS
man, i dont even know what a radio from a 2004 impala looks like.
sorry.
post #5 of 12 (permalink) Old 11-03-2006, 04:30 PM
Mike woods
Thanks.
1st- remove the fuse panel cover's on both side's of the dash.(2nd)remove the single screw that is in the side under that panel. (3rd) go under the dash at the pedal's and release the lower panel,and then remove the two screw's.(4th) gently pry the dash from the drivers side,and keep pulling gently all the way acrossthe whole dash,it is held by push in clips! (5th)unplug the hazzard light harness.(6th) remove the screw's in the stereo,and pull out and unplug the harness. re-install in reverse order.
post #6 of 12 (permalink) Old 11-03-2006, 08:11 PM
Mike woods
sorry.
i hate to say it!! but it's the same radio that is in the 94-96 impala ss . i installed a factory cd player in my 96 out of a 2000 chevy.
post #7 of 12 (permalink) Old 11-03-2006, 09:03 PM
jevz1
Thanks Impala2C. Your help is appreciated.
post #8 of 12 (permalink) Old 11-03-2006, 09:06 PM
jevz1
post #9 of 12 (permalink) Old 11-03-2006, 09:08 PM
jevz1
You're an a**hole MrCadillac. If this forum is full of people like you, I don't need it.
post #10 of 12 (permalink) Old 11-03-2006, 09:43 PM
96capriceMGR
Don't take it out on him when you did not look around enough to realize YOU were in the wrong place. This is the best b-body forum on the web.
My wife drives a w-body so I signedup on a w-body board(imagine that ) nowhere near the knowledge level that is available here, so while a w-body specific board is a better bet don't hold your breath on good answers.
