for the people with heavy bass. - Chevy Impala SS Forum
post #1 of 17 (permalink) Old 11-24-2006, 12:50 PM
DTXIMPALASS
how do you all keep the interior from getting loose. From weeks of loudass bass.
I want some hard hitting base but i dont want my door panely and everything else getting all loose.
post #2 of 17 (permalink) Old 11-24-2006, 01:23 PM
Jimsterlok
If your bass is loud enough to rattle something loose you must have hearing problems by now.
post #3 of 17 (permalink) Old 11-24-2006, 02:10 PM
DTXIMPALASS
HA LOL i havent even installed them yet for the simple reason that my other cars interior started getting loose...
post #4 of 17 (permalink) Old 11-24-2006, 04:08 PM
UndercoverPunk
I'm going to put in fresh fasteners every time I pull a door panel, That's all I really can think of thus far... I'll also be deadening the panels themselves when I strip the whole car out this summer... should be... lots of fun. You could also probably add some more padding behind the panel to make them a bit more solid to begin with.
And as far as hearing damage... as far as I've seen thusfar, a car is much less durable than my ears.
Last hearing test I took I still had perfect hearing, but my sedan is falling apart.
post #5 of 17 (permalink) Old 11-24-2006, 09:13 PM
B_Campbell
Frank, we can do a big buy on sounddeadner for our cars and just deaden the **** out of the front and rear panels, make them real solid, and you wont have anything to worry about once they're done.
post #6 of 17 (permalink) Old 11-25-2006, 02:23 AM
savagebee
sound deadening (I like the new fastener idea....)
just put it on very thick and squeeze the panel over it...
the problem is.. youll think its good... then youll put a stereo in... damn... you have some rattles.. okay.... you fix those...
then you put a 1200 watt amp and an 18" sub in there.. and you find a whole ****ton of rattles...
it never ends... if the stereo is loud enough.. youll always be chasing the rattles down...
post #7 of 17 (permalink) Old 11-25-2006, 12:59 PM
White whale
Normally the bass heads don't care if there car rattles apart. 90% of the SPL systems I have seen are crap installs, and that includes the world finals.
You can use dampening material, like dynamat or equivalent to stop rattles.
Tim
post #8 of 17 (permalink) Old 11-25-2006, 02:13 PM
UndercoverPunk
Tim
Crap installs?
I disagree completely.
post #9 of 17 (permalink) Old 11-25-2006, 02:43 PM
White whale
Originally posted by UndercoverPunk:
Crap installs?
[/QUOTE]
have you been to some major car audio shows, including the world finals, I have and being a professional installer I have seen my share of crap installs. OK I may have over exaggerated 80%
Tim
post #10 of 17 (permalink) Old 11-25-2006, 06:35 PM
chevmdnss
Tim
I agree!
