hooking up a 2nd battery to audio? - Chevy Impala SS Forum
post #1 of 15 (permalink) Old 10-20-2006, 07:21 PM
hevychevy
what is the proper way to wire a second battery to my audio system in the trunk? can anyone give me a draw up, i want to learn from the pros so i wont fry anything...
post #2 of 15 (permalink) Old 10-20-2006, 08:19 PM
USAFCaprice
heres all the info you need http://www.bcae1.com/battiso.htm
post #3 of 15 (permalink) Old 10-20-2006, 10:31 PM
hevychevy
by just having 2 batterys and fusing them, will this cause to much power going to the car or whatever?
post #4 of 15 (permalink) Old 10-20-2006, 10:54 PM
bbodyguy
The best way is the solinoid setup they have posted.
The two just fused together has smoe significant drawbacks. One battery that is not quite up to snuff will present a load to the other battery, and in time you will have two dead batteries.
Use the solinoid setup.
What problem are you trying to solve with the use of two batteries?
post #5 of 15 (permalink) Old 10-20-2006, 11:36 PM
the96pala
Yo man, Here's my power set up
250 alt. - Yellow top optima - 200a fuse - isolator - Yellow top Optima - both amps
1st batt: Power from alt to battery and then of course it is grounded.
Power wire is run to the fuse to the rear battery. two power wires are run from that battery to the amps, one to each amp. That battery is grounded to the car
post #6 of 15 (permalink) Old 10-21-2006, 02:50 PM
USAFCaprice
Cracka where'd you get the HO Alternator?
post #7 of 15 (permalink) Old 10-21-2006, 03:31 PM
bbodyguy
Voltage drop across the isolater may be more of a problem than whatever it is you are trying to solve.
post #8 of 15 (permalink) Old 10-21-2006, 06:43 PM
hevychevy
when i bang my sounds with my lights and heat on the batt. meter drops right before the 8
post #9 of 15 (permalink) Old 10-21-2006, 06:53 PM
marquinparks
How about cutting that damn music down?! How about keeping your hearing?! All that BOOM DITTY BOOM!
post #10 of 15 (permalink) Old 10-21-2006, 07:55 PM
bbodyguy
I doubt a second battery is going to help that much then.
You would be better off doing upgrades to the charging system, and maybe cables.
